  • June 30, 2025, 08:13:00 PM
Author Topic: Enya Model 5224 engines being produced again!  (Read 3726 times)
Offline pat king
    • PDK LLC
« on: November 12, 2007, 10:30:12 PM »
OK all you Enyaphiles out there. I was just at the Enya site (http://www.enya-engine.com/store/index.php). They are producing and selling new .29 IV and .35 III Model 5224 C/L engines. So, if you want a great starting, strong running, last forever engine, you can buy them NIB from Enya. The site doesn’t say if they come with both heads and three venturi inserts, but for stunt flying the 9.0 to 1 head and the #2 and #3 venturi insert are not necessary.
Pat  S?P
Pat King
Monee, IL
AMA 168941
Online Brian Hampton
Re: Enya Model 5224 engines being produced again!
« Reply #1 on: November 12, 2007, 11:54:48 PM »
Excellent! The 7000 yen for the 35 is roughly US$65 or about Aus$70. I've got the new version of the 60-IIIB and have just started running it in. With 50+ minutes so far the ring has barely started to run in. I could only see signs by taking a closeup photo then adjusting the brightness and contrast. However it's a one flick starter :).
Kaz Minato has been offering 20% off the factory prices...or he was when I got my 60 through him. http://homepage3.nifty.com/bluemax/MNT001.html
« Reply #2 on: November 13, 2007, 12:15:26 AM »
That means the old NIB .29's I've been saving are now worthless  :'(.
Offline dennis lipsett
« Reply #3 on: November 13, 2007, 05:05:04 AM »
Actually the problem is how can you buy a new one when all your old ones are not worn out ,and show no signs of ever wearing out.
dennis
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #4 on: November 13, 2007, 10:21:44 AM »
Well some of us don't have one.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Bob Zambelli
« Reply #5 on: November 13, 2007, 10:55:43 AM »
That's really good to hear - as far as I know, the only other .35 being made is the Fox.
In 1965 I bought one of the first series - came with two heads and three square venturis. I installed it in a green-box Nobler and with one homemade .015 head shim, it ran as well as any Fox.
I ran about a gallon of Superfuel through it before I flew it. Then, I made around 100 flights in the Nobler.
Then I put it in a Flite Streak and flew it for a season.
I still have the engine and it's almost broken in now!!  LL~ LL~ LL~
The second series 5224 had a round venturi.
« Reply #6 on: November 13, 2007, 01:25:09 PM »
That is what they used to tell me back in the late 50's about a Fox 35 Stunt.  Buy it,  run it on the bench to learn to start it.  Then fly it all summer and you might have it half way broken in.  It was also the same with Enya and OS Max when they first came out.  Have fun,  DOC Holliday
Offline Ron Merrill
« Reply #7 on: November 13, 2007, 01:32:49 PM »
Isn't it nice how the hits just keep coming for C/L engines these days. #^ #^ #^ Ron.
« Reply #8 on: November 13, 2007, 01:59:10 PM »
I think it's really great to see the resurgence.  #^ #^ #^
With engines like Randy's, Brodak's, Fox's and now some new Enya's, not to mention 4S C/L engines, we're being offered one heck of a choice!!  ~^ ~^
Just out of curiosity, is OS offering ANY C/L engine now?  ???
Offline pat king
    • PDK LLC
« Reply #9 on: November 13, 2007, 08:01:31 PM »
dennis
What about we fools who own a dozen of them?   y1 You are right they seem to last forever.
I can guarantee that they are broken in before they get to 200 hours.  LL~
Pat
Pat King
Monee, IL
AMA 168941
Offline Jim Oliver
« Reply #10 on: November 14, 2007, 07:21:30 AM »
Guys,
Do these new/old Enya engines require high castor fuel?
Jim
Jim Oliver
AMA 18475
« Reply #11 on: November 14, 2007, 07:48:47 AM »
Jim wrote:
"Guys,Do these new/old Enya engines require high castor fuel?
Thanks, Jim"
Although this might be better placed in the "engine" section, I will add my 2 cents.
Here in the northeast, we are running a variety of older engines using Powermaster 10-22 or Brodak 10-23, both having 50/50 castor/synthetic. Engines like older ENYAs, OSs, Coxs, K&Bs and of course the good old Fox .35. Ringed, lapped, ABC, ABN, AAN, AAC - you name it.
Some of the engines that I personally run include my OK Cub .049, a K&B .09, some Fox .35s and of course my Atwood Triumph .49. They ALL get the same castor/synthetic blend.
Countless people have told me that one MUST run as high as 30% ALL CASTOR or the engines would be ruined. Countless people were wrong.
All my engines still run flawlessly with no sign of lubricant related wear.
I experienced one major glow engine failure in the last ten years - a Surpass .40 that I bought used and then ran for years. The crankpin broke but there was NO SIGN of the usual lubricant related  failure issues.
I bought a very old Fox .35 that was not only well used but covered in baked-on castor oil. Even the exhaust port was partially blocked and the piston was black. As an experiment, I started running it on the Powermaster blend. It started out marginal and after around ten tanks of fuel became one of my best running Foxes. The outside still looks the same but the deposits burned out of the exhaust port and the piston color actually lightend up.
Offline Dan Labine
« Reply #12 on: November 14, 2007, 09:30:03 AM »
Ordered one on the net yesterday. I received an e-mail this morning that it was shipped. Isn't the internet amazing.. The world is so much smaller now.
Dan
MAAC 14300
Offline George
  • Love people, Use things.
« Reply #13 on: November 14, 2007, 10:03:01 AM »
Guys,
Jim
The original instructions for my 5224 .29 calls for 20% castor. Most people used all-castor back then. I would keep it at least half castor...just a personal preference. No need for extra high oil content. I would go with Bob Z.'s recommendations.
Many of us use the many-short-run/complete cool-down on a bench type break-in...Enya says just run it rich for awhile. Your choice.
I would read the instructions, perhaps they are using different metals now. Here are a couple of pics so guys will know what we are discussing:
George
George Bain
AMA 23454
