  • July 18, 2025, 04:06:25 PM
Author Topic: Engine choice for Twister. OS .35 Stunt or HP .40??  (Read 1726 times)
Offline frank mccune
« on: June 17, 2019, 03:45:02 PM »
          Which engine would be the better choice? Both can made to balance the plane by moving the engine.  I had a Twister powered by a HP .40 and it was a dream to fly.  I do not know if I would be satisfied with as OS .35 Stunt engine.
          Thoughts / Suggestions?
        Tia
Offline Brian Gardner
Re: Engine choice for Twister. OS .35 Stunt or HP .40??
« Reply #1 on: June 17, 2019, 06:12:32 PM »
The HP40 with my ABC stunt set in it would be magic in the Twister.
« Reply #2 on: June 17, 2019, 06:12:40 PM »
        Tia
It it definitely a .35 size plane.  Lots of guys fly it on an OS46LA.  I fly one with a Cobra 2820 electric which is a 46 size motor.  I think either is fine.  The .35 on 58' .014 lines is more power/weight than we flew PA in the 70's so I would pick whichever one is the most reliable.
« Reply #3 on: June 17, 2019, 07:20:54 PM »
        Tia
 Sounds like you've answered your own question.  ;D
Offline Naomi Macklem
« Reply #4 on: June 18, 2019, 06:00:36 AM »
My Twister has an OS LA .40 in it, and it flies amazing.
Offline James Holford
« Reply #5 on: June 19, 2019, 12:02:33 AM »
.46LA on 58' .015. Anything else is just a toy.
Sent from my SM-G965U using Tapatalk
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
« Reply #6 on: June 19, 2019, 04:04:04 PM »
What's your setup on the .40 LA/Twister? Prop, fuel, venturi size, muffler, weight and line size & length?  #^ Steve
Offline Istvan Travnik
« Reply #7 on: June 19, 2019, 04:59:34 PM »
HP 40.
And try to obtain it with original, genuine venturi, with original one-side nozzle type needle assy. (I think MECOA offers it).
« Reply #8 on: June 19, 2019, 06:56:54 PM »
Yes they do
HP 40.
« Reply #9 on: June 19, 2019, 11:34:26 PM »
Actually, one of the engines you mentioned in the first paragraph of this thread is in my opinion a nearly perfect match for a Twister.
If you have a GOOD ONE... the OS35S is the perfect Twister engine!
