General control line discussion => Open Forum => Topic started by: frank mccune on June 17, 2019, 03:45:02 PM
Which engine would be the better choice? Both can made to balance the plane by moving the engine. I had a Twister powered by a HP .40 and it was a dream to fly. I do not know if I would be satisfied with as OS .35 Stunt engine.
Thoughts / Suggestions?
Tia
The HP40 with my ABC stunt set in it would be magic in the Twister.
Tia
It it definitely a .35 size plane. Lots of guys fly it on an OS46LA. I fly one with a Cobra 2820 electric which is a 46 size motor. I think either is fine. The .35 on 58' .014 lines is more power/weight than we flew PA in the 70's so I would pick whichever one is the most reliable.
Tia
Sounds like you've answered your own question. ;D
My Twister has an OS LA .40 in it, and it flies amazing.
.46LA on 58' .015. Anything else is just a toy.
(https://uploads.tapatalk-cdn.com/20190619/ded38fc5f780fd86d39df7ff9dbb793a.jpg)(https://uploads.tapatalk-cdn.com/20190619/0f03b469c8a7aef94587647085c615f8.jpg)(https://uploads.tapatalk-cdn.com/20190619/5df0de167aa22a074fb49e287e105561.jpg)(https://uploads.tapatalk-cdn.com/20190619/150bbad98fea48bbfaf60b416fa818d5.jpg)
Sent from my SM-G965U using Tapatalk
What's your setup on the .40 LA/Twister? Prop, fuel, venturi size, muffler, weight and line size & length? #^ Steve
HP 40.
And try to obtain it with original, genuine venturi, with original one-side nozzle type needle assy. (I think MECOA offers it).
Yes they do
HP 40.
Actually, one of the engines you mentioned in the first paragraph of this thread is in my opinion a nearly perfect match for a Twister.
If you have a GOOD ONE... the OS35S is the perfect Twister engine!
