  • June 24, 2025, 04:47:16 PM
Author Topic: tongue mufflers  (Read 1481 times)
Offline Fred Shattuck
tongue mufflers
« on: May 08, 2008, 12:42:07 PM »
Would someone please explain what a tongue muffler is, advantages, disadvantages, etc?   Thanks    FRED
Offline Bill Heher
  • Fix-it
Re: tongue mufflers
« Reply #1 on: May 08, 2008, 12:57:34 PM »
They are small flat blade style mufflers that the exhaust usually exits through a series of small diameter holes drilled in the lower face. Sort of like a muffler extension with the end closed off and holes drilled in it to allow the exhaust out.
They are usually lighter, more compact and easier to fit a cowling around. They can also be "tuned" to your application by changing the amount of backpressure through adding or plugging holes.
Bill Heher
If it's broke Fix-it
Re: tongue mufflers
« Reply #2 on: May 08, 2008, 01:09:11 PM »
Thanks, I've seen them, but did not know what I was seeing.   Can they be used to pressurize a fuel tank?   Thanks,    FRED
Offline Tom Perry
Re: tongue mufflers
« Reply #3 on: May 08, 2008, 04:54:55 PM »
They can be and are used for that purpose.  When you look at some of the many photos here take a gander at how the mufflers are rigged.
Tight lines,
Tom Perry
 Norfolk, Virginia
