  • July 09, 2025, 11:14:57 PM
Author Topic: uni knot  (Read 758 times)
Offline Bootlegger
uni knot
« on: November 12, 2015, 01:25:19 PM »
 What are y'all doing to get the lines even when tying this knot? Do you wet the knot so that it will pull up tight?
 Any help/suggestions that y'all can come up with will be greatly appreciated..
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: uni knot
« Reply #1 on: November 12, 2015, 03:18:43 PM »
Practice is all I can say.   Also use the old EZ-Just handle.
As I hit the send button it occurred to me the fiber handle and line we used to get in 1/2A kits.    Thread the lint through the handle.  Tie loose ends to the plane.   Centered line similar to the EZ-Just.  Most events you are allowed 6 inches.
Offline Phil Krankowski
Re: uni knot
« Reply #2 on: November 12, 2015, 05:44:27 PM »
Yes, moisten the knot before trying to take it fully tight.
Tie one end of both lines, then stretch them out, measure and mark them with a sharpie.  Include the mark in the knot.  With a little care it is reasonably easy.
Phil
