  • June 30, 2025, 02:16:55 AM
Author Topic: plotting drawings  (Read 1388 times)
Offline Lynn Weedman
  • x47weed (Lynn Weedman)
plotting drawings
« on: August 09, 2010, 04:34:27 AM »
This may not be the right area to post this one, but I need to know if anyone's got the directions to change the carriage drive belt on a HP 750C PLOTTER ? I'm trying to get my latest twin design completed.
Lynn Weedman
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
Re: plotting drawings
« Reply #1 on: August 09, 2010, 08:34:01 AM »
Try Googling something like "HP 750C manual". I've gotten many manuals in PDF form in this manner.
Good luck,
L.
"Always carry a flagon of whiskey in case of snakebite and furthermore always carry a small snake." -W. C. Fields
Offline Neville Legg
« Reply #2 on: August 09, 2010, 10:20:13 AM »
I've changed the belts on HP 430's 500's and 800's (it's what I do for a living!) never seen a 750! did you not get instructions with the belt?
Cheers  Neville
(not) Descartes
Offline Thomas J. Weedman II
  • T.J. Weedman
« Reply #3 on: August 10, 2010, 05:59:20 AM »
"Complicated Machines for Dummies" uncle lynn  ;)
Offline RogerGreene
« Reply #4 on: August 12, 2010, 08:11:09 PM »
I have an HP 755CM and I have changed the drive belt and the motor that drives it. the motor is on the control panel side.  The belt and drive pully on the motor were stripped. You have to take the left side totally apart. Very messy cause this is where the pens are cleaned. If you contact HP they can tell you where to get the parts cause they don't have them any more the plotter os too old.
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
Tags: for all to read
