  • July 17, 2025, 09:25:08 PM
Author Topic: doped silkspan////// Freshly done  (Read 2582 times)
Offline Chuck Feldman
« on: October 17, 2006, 01:17:17 PM »
Working on a poor surface I managed to dent the silkspan in one bay. I spent yesterday putting up a good table and then I went out and bought a nice foam pad for it. The foam is covered with a nice cloth now so I should be OK working on models in the future. I was masking out the model when I damaged the silkspan. It was on one of those PVC racks we all seem to have!
OK so if any of you have a method to get the dents out I would really like to know how you do it.  Medium silkspan, Brodak dope
Salute
Chuck Feldman
Chuck Feldman
AMA 15850
Offline frank carlisle
Re: doped silkspan////// Freshly done
« Reply #1 on: October 17, 2006, 01:21:58 PM »
Chuck,
I don't know where you are at in the finishing process. If you are at the beginning you should be able to get the dent out by re-wetting it and letting it re-shrink. I'd try that first.
Frank Carlisle
« Reply #2 on: October 17, 2006, 01:26:45 PM »
Frank,
I have finished putting on the first color. I have the silver covered and I was masking out for the first coat of trim color when I screwed it up.
Chuck
Chuck Feldman
AMA 15850
Offline Richard Grogan
« Reply #3 on: October 17, 2006, 01:31:11 PM »
Frank,
Chuck
How big a dent is it Chuck?
Long Live the CL Crowd!
                  AMA 85745
« Reply #4 on: October 17, 2006, 01:41:37 PM »
Richard,
There are two dents both are dime size or smaller but not much. There is also a split that is on an edge I figure that one I can handle with patch. I got lucky because this is all on the bottom left wing.
Chuck
Chuck Feldman
AMA 15850
« Reply #5 on: October 17, 2006, 02:58:57 PM »
Id try what Ty recommended, but it probably won't come out "invisible"..Good thing it was on the bottom! If that won't work and its still important to you, time to do some patch work. Maybe you could put a sticker or trimsheet design over it to dress up the bottom a little; do it on both sides of the wing! 8)
Good luck!
RG
                  AMA 85745
« Reply #6 on: October 17, 2006, 06:20:51 PM »
Hey Chuck,
I think the guys have given you a good plan for getting the dents out.
It's a good thing you got the padding that will certainly help. Problem with padding the table is that you can still set the model down on a tool and get dents.
I used a piece of styrofoam that came in the box of a new television to make a pedestal to put the plane on. There is no room on the pedestal for exacto knives or any other tools so I manage to get through the finish without damaging the plane by setting it on tools. I also have a couple 1 X2 sticks I padded for working on the fuselage sides. I highly recommend having these.
I took a couple pictures for you to look at.
Frank Carlisle
Eric Viglione
« Reply #7 on: October 17, 2006, 08:37:48 PM »
OR... Get a Byron Barker paint stand, and you never have to set the plane down on anything.  y1
BTW, Byron should rename that thing to a building stand or finishing stand, because once the wing is in the fuse, I put it in the stand and it doesn't come out until the clear is on. I just got mine this year, and don't know how I ever lived without it!!!  #^
EricV
Offline RC Storick
« Reply #8 on: October 17, 2006, 08:51:34 PM »
Me too, there GREAT!!!
« Reply #9 on: October 17, 2006, 10:45:17 PM »
I have one of the first stands that Byron made many years ago.....  It is a necessity!!  y1
Bill <><
« Reply #10 on: October 18, 2006, 04:14:53 AM »
You guys are great friends!!!!!!!!!   Great advice and tips. I will take some pictures (Before & After)  and post them for you all to see. Look for them next week.
Chuck
Chuck Feldman
AMA 15850
Offline Jim Thomerson
« Reply #11 on: October 18, 2006, 12:20:21 PM »
You should be able to get the dents out with a hair dryer.
