Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 14, 2025, 10:05:18 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
cleaning
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: cleaning (Read 1188 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
cleaning
on:
June 25, 2010, 06:47:09 AM »
Folk's what do you use to clean your models for the top coats of clear? ( auto or dope) I want to get as many foriegn particals off as possible Thanks
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
W.D. Roland
AMA Member and supporter
Trade Count:
0
Admiral
Re: cleaning
Reply #1 on:
June 25, 2010, 07:53:20 AM »
Hi Gil
Automotive grease/oil/wax remover ( pre cleano) then tack rag(cheese cloth?)
Just to be safe test on area where if it messes up paint you wont see it.
So fare has been good with all paint I have used.
Helps to wet down the floor or ground to hold the dust down.
David
Logged
David Roland
51336
john e. holliday
25 supporter
Trade Count:
0
Admiral
Re: cleaning
Reply #2 on:
June 25, 2010, 08:14:43 AM »
First go wash your hands thoroughly. Get some gloves and a bag of non lint rags. Then start wiping. If I think there is oil on the surface I use a rag dampened with Windex. I tied cleaners once and it removed some of the dope finish. All this is after the primary coat is done. Then it is wash hands and gloves every time I work on the plane.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: cleaning
Reply #3 on:
June 25, 2010, 10:08:08 AM »
I've used PrepSol in the past (basically Naphtha) but more recently I've taken Phil Granderson's advice and used Windex. No problems.
Logged
Bootlegger
22 supporter
Trade Count:
0
Admiral
Re: cleaning
Reply #4 on:
June 25, 2010, 06:25:52 PM »
Thanks guy's, all very good suggestions.. Thanks a lot...
Logged
Gil Causey
AMA# 6964
Will Davis
25 supporter
Trade Count:
0
Admiral
Re: cleaning
Reply #5 on:
June 25, 2010, 08:04:45 PM »
Windex or Dupont Prepsol to clean . , For shop towels , stay away from anything that has been washed or dried, dryer sheets have alot of silicone in them , Best to use 3M prep cloth but kinda expensive , but so is repainting .
Will
Logged
Will Davis
"Carolina Gang"
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
cleaning
