  • June 29, 2025, 05:18:23 AM
Author Topic: Do Over  (Read 2193 times)
Do Over
« on: January 24, 2022, 07:30:58 AM »
I might refinish a plane. What are your experiences with removing a dope finish down to the wood without compromising glue joints?
Offline GallopingGhostler
Re: Do Over
« Reply #1 on: January 24, 2022, 07:47:55 AM »
Careful and patient hand sanding. Using a sanding block helps.
Offline bill bischoff
Re: Do Over
« Reply #2 on: January 24, 2022, 08:20:32 AM »
I have had some success with using a heat gun to peel off old silkspan and dope. I would avoid using chemicals and stick to mechanical removal methods.
Offline mccoy40
Re: Do Over
« Reply #3 on: January 24, 2022, 08:22:46 AM »
Dope thinner might help - you should also be thinking about how to re-glue if you need it
Joseph Meyer
Philadelphia, PA
Re: Do Over
« Reply #4 on: January 25, 2022, 04:07:51 PM »
Great info Bob!!!
Thanks I’m motivated!!!
Offline Phil Spillman
Re: Do Over
« Reply #5 on: January 25, 2022, 07:11:53 PM »
Hi Paul, In 1992 I stripped an old Ringmaster with Zip Strip and it worked great! Now I wonder if it would work as well today 30 years later! I'd give it a try though! if all else fails use acetone sparingly hopefully the model wasn't built with with Ambroid although mine was! it still is flying. I built it for my son in 1976 and it was an original Sterling kit with heavy wood! I did rehinge the elevator with Goldberg Nylon 1" tape t works quite well!
Phil Spillman
Phil Spillman
Re: Do Over
« Reply #6 on: January 26, 2022, 08:33:59 PM »
Phil Spillman
Thanks for the tip ole friend.
I will keep y’all posted.
Re: Do Over
« Reply #7 on: January 26, 2022, 09:00:15 PM »
A/ youll make a big mess . So a sealed area or outdoors or something , helps . Like a vacume cleaner on standby alert ! .
B/ Throwing rags / paper towels rather damp with acetone , softens big areas , to peel off .
CHISELS even when oversharp tend to dig in . Gotta usem upsidedown .
A hacksaw Blade, NEW . Dragged across like a slicer , lostens the covering , then peel . Work sticky spots .
The more dope under the covering the better its stuck . Just Butrate peels easy .
80 Wt sandpaper new & sharp , often replenished , on decent blocks / forms , to cut through stuck parts , initially .
The glue seams , right angle corners need the most patiance & care . A paint scraper to fold the paper over , or a few steel straight edges ( dosnt do them a lot of good )
a selection of square , triangle , half round & flat files , B'std first , are good too . One flat with one plain edge is handy . Newish ones work best . DONT DROP THEM ON IT .
Yerinfer a few days work . Whacking off the control surfaces is a good idea . Slicing over & under hinges & stabing edges , the pull easy / o.k. , with a bit of a wriggle & the odd re cut .
Bob's trick was / is to re fit timber in the holes resulting, and re cut slots . In one of his artiles at least .
So , youll be in for new hinges , too . If Fitted .
Re: Do Over
« Reply #8 on: January 28, 2022, 08:51:12 AM »
Thanks Bob
I was going to ask you how you got the hinges out.
I know for some it’s easier to just build a new plane but I hate giving up on a plane just cause I got heavy handed with a paint gun. 🤪
It looks straight and it did not do anything weird in flight. I will give it one more try.
Offline Serge_Krauss
Re: Do Over
« Reply #9 on: January 28, 2022, 09:21:54 AM »
When I stripped my P-Force a few years ago, I first tried with acetone. For that Brodak finish, I found that "Dad's" paint stripper actually worked significantly better than acetone in removing the silkspan.
