  • July 14, 2025, 12:16:20 AM
Author Topic: Delete a comment?  (Read 2162 times)
Offline Chris Fretz
Delete a comment?
« on: September 18, 2016, 02:08:28 PM »
Just curious but can you delete a comment that you have made in a thread? I thought I saw that option a wile back but I don't see it anywhere anymore.
Formerly known as #Liner
AMA 1104207
Advanced
Offline Leester
Re: Delete a comment?
« Reply #1 on: September 18, 2016, 02:23:54 PM »
click on the Modify which is the same as edit.
Leester
ama 830538
« Reply #2 on: September 18, 2016, 02:43:30 PM »
remove
« Last Edit: September 19, 2016, 09:18:40 AM by Motorman »
Offline Chris Fretz
« Reply #3 on: September 18, 2016, 03:30:12 PM »
I saw you could modify the comment but how do you actually delete or remove it?
AMA 1104207
Advanced
Offline Leester
« Reply #4 on: September 18, 2016, 03:56:17 PM »
When you click on the modify click at the end of your comments and backspace until everything is gone, the click on "save changes" or what ever it says. I'll bet alot of people have Motorman on there ignore list also !!
Leester
ama 830538
Offline Chris Fretz
« Reply #5 on: September 18, 2016, 03:59:38 PM »
It will just say "the message body was left empty" and doesn't save it.
AMA 1104207
Advanced
Offline Leester
« Reply #6 on: September 18, 2016, 04:06:59 PM »
get ahold of the forum moderator and ask to have it deleted.
Leester
ama 830538
Offline Dane Martin
  • heli pilot BHOR
« Reply #7 on: September 18, 2016, 04:18:01 PM »
You could delete it all and put a period. Then it'll save it
Online Steve Helmick
« Reply #8 on: September 18, 2016, 04:18:31 PM »
Although you can delete the text of your comment, you can't remove the fact that you made a comment. Best you can do on your own is to "modify", put any word or punctuation mark, and then save it.  D>K Steve
Offline Chris Fretz
« Reply #9 on: September 18, 2016, 04:28:07 PM »
Oh I ment to delete it so you won't keep getting new replies from a thread you want to stop following.
AMA 1104207
Advanced
Offline RC Storick
« Reply #10 on: September 18, 2016, 05:09:48 PM »
Click notify again and un-follow
Offline RC Storick
« Reply #11 on: September 18, 2016, 05:32:57 PM »
Point me to the thread and I will delete it
Offline Chris Fretz
« Reply #12 on: September 18, 2016, 05:57:16 PM »
Thanks!
The un-follow under notify will work thanks.
AMA 1104207
Advanced
« Reply #13 on: September 18, 2016, 09:52:06 PM »
remove
« Last Edit: September 19, 2016, 09:18:04 AM by Motorman »
« Reply #14 on: September 18, 2016, 11:38:40 PM »
Some of the forums, including the "OPEN" forum have a button that allows you to delete and completely remove one of your own posts. Other forum sections do not have the option.
Rusty
