Entering the Nat's is a possible in the future for me but even so I do build mostly as if every contest were BOM.
I wish that all stunt events would be BOM.
A possible simple solution from a simple mind.(KISS) might be 2 simple rules:
1-Not allow commercially produced ARFs.
2-Sign affidavit declaring BOM.
#2 will not stop someone from secretly having an airplane built by another and having to lie to fly but we never do achieve 100% in anything involving humans.
How would you deal with the one in a 10000 that would have someone else build thew airplane and at intervals during construction have pictures taken with his self, not the actual builder in the picture and then present it as
BOM?
Now for the Rambling on,,,,,,,,,,
But to make pre-sheeted Foam wing's illegal makes as much sense as pre-molded cowl's, wheel pants, canopies and other such parts being illegal.
Should pre-shaped flaps or pre bent landing gear be listed as a No No?
Should parts like the molded plastic top on Sigs P-51 make this airplane illegal?
Would it be BOM compliant to scratch build my own design using a sheeted foam wing bought from one of
our own good guy fellow fliers?
What would happen if someone was nuts enough to want to build the FW190 I'm doing?
If I mold a balsa fuselage and send to him with rib patterns and so called plans for him to spend 100s of hours building is that BOM compliant?
Would including the molded Fiberglass cowl and gun hood make a diffrence?
Instead of rib patterns I supply a sheeted & cored foam wing from another source is this BOM legal?
What if I loose my mind and make molds for production of all parts in Carbon Fiber then the Builder would assemble from 50+ separate molded parts? THIS METHOD WOULD BE EXTREMELY TIME CONSUMING FOR THE BUILDER.
Time for the box full of wheel pants, cowls from various that I have been saving for the last 1/4+ century to go
into the trash?
The BOMer in me is nearing the finished airframe stage on the FW so.....
H^^to all
David
