  • July 22, 2025, 05:09:10 AM
Author Topic: Cutting foam wings  (Read 986 times)
Cutting foam wings
« on: June 10, 2009, 04:05:54 PM »
I have a lot of respect for the guys that cut foam wings. I have watched all kinds of videos on doing this. The guys make it look easy.
I have tried to cut two complete wings. One for a small sport plane and it did not turn out that great. Still stilling on the shelf. I got templates for a Tutor 2 wing. Tapper on the LE. I went thru a 15 inch block of foam and did not get one good pannel. I get to the LE and I am not sure because the outside template is way smaller I put a diviot in the LE. Dang-nab-it. Rasfrasen ^&#$%... Bleepity-Bleep!
 HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~>
But I will keep on trying till I get a good one.
Offline sleepy gomez
Re: Cutting foam wings
« Reply #1 on: June 10, 2009, 10:29:26 PM »
Rootbeard, call me.  863-899-0656  SLEEPY
« Reply #2 on: June 11, 2009, 06:58:39 AM »
Myself I start at leading edge and go towards the trailing edge.  That is why I use what used to be cheap foam sheets from the local lumber yard.  They are not cheap anymore or they see  me coming.  DOC Holliday
« Reply #3 on: June 11, 2009, 03:15:45 PM »
Sleepy tried to call and got Vmail. Will try again tomorrow.
