  • June 25, 2025, 01:46:27 PM
Author Topic: New project for 2023  (Read 2023 times)
Offline Peter Germann
« on: January 03, 2023, 06:31:42 AM »
« Last Edit: January 11, 2023, 01:47:49 AM by Peter Germann »
Peter Germann
Teodorico Terry
Re: New project for 2023
« Reply #1 on: January 03, 2023, 01:00:26 PM »
Tried the link but it did not seem to work.
Offline Paul Wescott
« Reply #2 on: January 03, 2023, 03:00:12 PM »
The link eventually provided a PDF which showed a 2-view (see photo)
« Reply #3 on: January 03, 2023, 03:35:02 PM »
Indeed it does. Takes awhile to download is all.
I noticed that the elevators are without a fairing to the fuselage and quite  long elevator horn connector wires would be needed. Is there a reason for this?
I would want to keep the iron in the back end at a minimum is all. I've also wondered when somebody would design light weight CF control horns to eliminate the old wire designs from the 1950's. I don't think it's impossible, at least.  H^^ Steve
Offline frank williams
« Reply #4 on: January 03, 2023, 05:37:58 PM »
Nice looking plane ...
I noticed the 1 in. offset in the wing .....and ...  I also noticed the 1/2 inch offset in the  stab. span.
« Reply #5 on: January 04, 2023, 03:41:33 AM »
The gap between the outer elevator and the fuselage provides space for the adjustable rudder pushrod.
Here are the mechanical detail drawings for Replica 23:
https://www.mycloud.ch/s/S000A15BE0306254FEE3BE135A36046D4C37218A187
Dimensions are in metric millimeters. Divide by 25.4 to get inches
« Last Edit: January 04, 2023, 04:45:35 AM by Peter Germann »
Peter Germann
Online Bill Hummel
« Reply #6 on: January 04, 2023, 12:05:57 PM »
Hello, Peter!  Very nice design, a bit “out of the box”, I like it!  Could you tell me what airfoil you are using?  Thank you…
ama 72090
« Reply #7 on: January 05, 2023, 03:27:43 AM »
Thanks for asking, Bill.
Root profile is symmetric with max. thickness (with flaps) of 20% at 28% depth and a blunt nose radius of approx. 1 mm or 1. 2 in.
Tip thickness is 16%
For details klick on:
https://www.mycloud.swisscom.ch/s/S000A15BE0306254FEE3BE135A36046D4C37218A187
and download "Rippen 1-2" and "Rippen 15"
Peter Germann
« Reply #8 on: January 05, 2023, 12:04:09 PM »
My German isn't adequate to figure out which .pdf files to open, so that didn't go well!
When I worked (machinist), I much preferred to multiply millimeters by .03937 to convert to inches. Gets the same answer, but it sort of reinforces the fact that 1mm is awful close to .040". I converted metric drawings enough that the .03937 is something I'll never forget...at least until I can't remember my own name.
The last time we had a push to adopt the metric system was in the early 1980's, and while I was in favor of it, industry here quashed it as too costly. I was working at Boeing at the time. If it came up now, I'm pretty sure the political machine in Washington DC would write a law and jam it through anyway. And probably make it a criminal offense to use inches or mph.  R%%%% Steve
Offline kevin king
« Reply #9 on: January 06, 2023, 01:24:36 AM »
Damn. How the heck do you come up with those fancy dancey paint scemes??
« Reply #10 on: January 11, 2023, 01:48:12 AM »
Peter Germann
