  • June 23, 2025, 12:59:34 AM
Author Topic: Sig Twister Wing Ribs  (Read 932 times)
Offline Airacobra
« on: August 12, 2020, 09:16:56 AM »
Does anybody do a Laser cut set of these ribs? The ribs in the kit were rock hard and heavy, yes I could cut a new set, but was checking to see if any laser cut ones were available first.
Keith Bryant
Re: Sig Twister Wing Ribs
« Reply #1 on: August 12, 2020, 09:39:11 AM »
Just a thought.  Mine were the same, maybe not as bad but harder than I wanted.  I just hollowed them out more.  I wasn't overly concerned with weight since I was building electric and I needed something to balance that obscenely heavy battery.  I came out at 52 oz and it flew like it thought it was a PA.  In all fairness, I added half ribs and an extra 4" of span to support the weight.
Offline ericrule
« Reply #2 on: August 12, 2020, 10:11:46 AM »
Mike at RSM has the laser cut file for the ribs. Call him at 951-678-1406 or e mail an order to him at rsm1rule@rsmdistribution.com. You can also order through the web site.
Offline Airacobra
« Reply #3 on: August 12, 2020, 07:27:48 PM »
Looks like Mike does not have them, I will seek out another source. Thanks for the try!
Keith Bryant
Offline Geoff Goodworth
« Reply #4 on: August 12, 2020, 08:55:45 PM »
Check with Walter.
He should have the cutting files for Bob Kruger's Fancher Twister.
Online John Rist
« Reply #5 on: August 12, 2020, 09:12:49 PM »
Check with Walter.
His web site is  http://www.builtrightflyright.com
Offline builditright
  • So happy to be alive!
« Reply #6 on: August 12, 2020, 09:16:29 PM »
Hi Keith, yes I make the Fancherized Twister, so I can cut you a set if you like.
I know they're the same but I can also cut them for the Banshee if you want them too. Just covering all the bases. ;)
Can cut them from 1/16 or 3/32 regular wood or Contest wood if you like.
Thank you and God Bless
Walter
aka/ builditright
Offline Airacobra
« Reply #7 on: August 13, 2020, 06:57:40 AM »
Walter, that would be great to have a set of Twister Ribs from 3/32. Email me the cost @ acsd2703@yahoo.com  Thanks Walter!!
Keith Bryant
