General control line discussion => Open Forum => Topic started by: Airacobra on August 12, 2020, 09:16:56 AM
Does anybody do a Laser cut set of these ribs? The ribs in the kit were rock hard and heavy, yes I could cut a new set, but was checking to see if any laser cut ones were available first.
Just a thought. Mine were the same, maybe not as bad but harder than I wanted. I just hollowed them out more. I wasn't overly concerned with weight since I was building electric and I needed something to balance that obscenely heavy battery. I came out at 52 oz and it flew like it thought it was a PA. In all fairness, I added half ribs and an extra 4" of span to support the weight.
Mike at RSM has the laser cut file for the ribs. Call him at 951-678-1406 or e mail an order to him at rsm1rule@rsmdistribution.com. You can also order through the web site.
Looks like Mike does not have them, I will seek out another source. Thanks for the try!
Check with Walter.
He should have the cutting files for Bob Kruger's Fancher Twister.
Check with Walter.
His web site is http://www.builtrightflyright.com
Hi Keith, yes I make the Fancherized Twister, so I can cut you a set if you like.
I know they're the same but I can also cut them for the Banshee if you want them too. Just covering all the bases. ;)
Can cut them from 1/16 or 3/32 regular wood or Contest wood if you like.
Walter, that would be great to have a set of Twister Ribs from 3/32. Email me the cost @ acsd2703@yahoo.com Thanks Walter!!
