  • July 20, 2025, 05:42:44 AM
Author Topic: Cox .010 ro .020?  (Read 1735 times)
Offline Phil Coopy
Cox .010 ro .020?
« on: November 01, 2007, 09:13:22 PM »
What can I measure to tell if I have a Cox .010 or .020?
Phil
Offline Scott Hartford
Re: Cox .010 ro .020?
« Reply #1 on: November 01, 2007, 09:16:50 PM »
.010 has a plastic tank or radial mount.
Alan Hahn
« Reply #2 on: November 01, 2007, 10:07:43 PM »
The TeeDee 020 is about 1 1/2 inches from the bottom of the crankcase to the tip of the glow plug. It also does NOT have beam mounts---I am not sure about the TeeDee 010 in that regard.
Offline Robert McHam
« Reply #3 on: November 01, 2007, 10:33:15 PM »
Hold up a regular pencil eraser next to the cylinder next to the piston. the .010 piston diameter is about the size of the eraser that is showing. The .020 piston is noticeably larger in diameter than the pencil eraser.
Robert
Offline Clancy Arnold
Re: Cox .010 or .020?
« Reply #4 on: November 02, 2007, 07:12:43 AM »
I just measured one each of my engines with the folowing:
Engine             Cox 010             Cox 020
Head               .432 Dia.            .556 Dia.
Overall height    1.238                1.524
Note: Overall height is measured from the two lower bosses on the crankcase to the top of the glow plug (head) connector.
An other quick check is that the 020 engine (PeeWee) normally uses 4 mounting screws and the 010 uses 2 mounting screws.
Clancy Arnold
U/Tronics Control
Offline Phil Coopy
« Reply #5 on: November 02, 2007, 10:06:18 AM »
Thanks guys,  mine measures out to be a .020, it has a metal tank and backplate...not a TD..a Pee Wee.
Phil
Alan Hahn
« Reply #6 on: November 02, 2007, 10:45:11 AM »
FWIW, there was no reed valve version of the 010, it was a Tee Dee (anyway as AFAIK)!
« Reply #7 on: November 02, 2007, 01:37:20 PM »
Allen
As far as I have found, you are correct.  The Cox 010 was only sold as a TD.
I have 2 Cox 010 TD's and 6 Cox 020 PeeWee runners.  I also have 1 020 with a broken crank. Looks like it landed at 90 degrees at full power.  I am using it as a parts engine.
I am considering building a Blohm & Voss Bv 138 for 1/2 A multi scale with 3 of the Cox 020 PeeWee's for power.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #8 on: November 02, 2007, 03:28:29 PM »
Allen
Clancy
That would be a fine thing to see! Good luck. The Bv 138 should make an exciting model to have on the flight line.
Robert
