  • July 16, 2025, 10:29:25 AM
Author Topic: Control line lead outs  (Read 1341 times)
Offline Ed
« on: December 29, 2006, 12:23:10 PM »
I just might be a novice but I'm going to ask anyway; Is it possible to mount the lead outs outside a build up wing?
Offline John Miller
Re: Control line lead outs
« Reply #1 on: December 29, 2006, 12:32:34 PM »
Yes Ed, it is possible to do so. What you need to be aware of is where, in relation to the vertical CG, your leadouts will wind up.  Having to great a difference can cause the plane to bank either in or out in flight.
Offline Leester
« Reply #2 on: December 29, 2006, 12:36:43 PM »
Most Bi-Planes are done like this. Check out Walter Umlands web site www.builtrightflyright.com and go to CR-32 photos it should show it.
Leester
ama 830538
Offline Clancy Arnold
« Reply #3 on: December 29, 2006, 12:38:23 PM »
In controline scale it is normal to place the leadouts outside the wing, for example my Cessna 152, which is a high wing plane, they are 2 1/2 inches below the wing, on my F/A-18 they are 1 inch above the tip.
Clancy
Clancy Arnold
U/Tronics Control
Offline Ed
« Reply #4 on: December 29, 2006, 12:45:47 PM »
Cool, that would make it much easier to adjust trim.
