  • July 17, 2025, 09:45:13 PM
Author Topic: Converting Regular to Uniflow  (Read 776 times)
Offline DanielGelinas
« on: August 25, 2011, 10:11:37 AM »
Hi all,
I have a pile of regular metal tanks I would like to convert to uniflow.
Is the answer as simple as changing the regular fill tube to a longer (to the back, outboard) tube and resolder? Do I need to open up the sides for this?
Also, what type of soldering tools do you use? Electric, Butane...?
I have a Weller soldering gun in the 900 to 1100 degree range. Is that OK?
-danny
Offline David M Johnson
Re: Converting Regular to Uniflow
« Reply #1 on: August 25, 2011, 10:19:01 AM »
As far as the solder gun goes that is what I've used with good success. remember to test for leaks after you make your alterations.
David Johnson
We're havin some fun now!!
« Reply #2 on: August 25, 2011, 12:27:30 PM »
Thanks for the info Guys!
-D H^^
