  • July 17, 2025, 07:02:19 PM
Author Topic: cloth hinges  (Read 1784 times)
Offline Joe Hunt
cloth hinges
« on: August 06, 2019, 05:25:19 AM »
new to this, using the forum that is. building a super clown and want to use cloth hinges. the wings and surfaces will be covered in silk. is it better to apply the hinges before or after silking?   thanks
Re: cloth hinges
« Reply #1 on: August 06, 2019, 06:26:02 AM »
Hi Joe.  I always applied hinges first-then covered. I'd guess most did.  Try to let a minimum amount of dope or covering get into the hinge line-makes for really stiff controls.
Offline Joe Hunt
Re: cloth hinges
« Reply #2 on: August 06, 2019, 08:19:41 AM »
 thanks, joe
Online Mike Griffin
Re: cloth hinges
« Reply #3 on: August 06, 2019, 09:33:01 AM »
What Ty said.  I apply hinges first.  Love Dacron hinges.
Online 944_Jim
Re: cloth hinges
« Reply #4 on: August 06, 2019, 10:09:54 AM »
Bear in mind I build small (1/2/A). Been sewing mine since I can't.seem to find any more Perfect or Goldberg small cloth hinge material. Where are you guys finding yours? I'm about to hit Walmart for light weight, narrow binding tape-like for old baby blankets.
Re: cloth hinges
« Reply #5 on: August 06, 2019, 11:10:11 AM »
Doesn't Morris sell the stuff?
Also, I believe there was a building hint about rubbing talcum powder into the center part of the hinge to keep paint out and to keep it flexible.
Offline Joe Hunt
Re: cloth hinges
« Reply #6 on: August 06, 2019, 11:30:54 AM »
i'm using the light 2" polyester rib stitching tape used to cover wing rib stitches on full size airplanes. the edges are pinked so I take the wife's pinking shears and cut cross grain the width I need. I use non tauting nitrate dope to attach. joe
Online Mike Griffin
Re: cloth hinges
« Reply #7 on: August 06, 2019, 12:00:09 PM »
You can buy the Dacron from Aircraft Spruce.  A square yard will last for years.
Offline Jim Hoffman
Re: cloth hinges
« Reply #8 on: August 06, 2019, 08:13:11 PM »
I use polyester taffeta when the need arises.  Available from your local fabric store
Re: cloth hinges
« Reply #9 on: August 08, 2019, 08:38:43 AM »
 I use one pin style hinge next to the flap horn then do the rest with cloth.
This takes a lot of stress off cloth hinges
