General control line discussion => Open Forum => Topic started by: Joe Hunt on August 06, 2019, 05:25:19 AM
Title: cloth hinges
Post by: Joe Hunt on August 06, 2019, 05:25:19 AM
new to this, using the forum that is. building a super clown and want to use cloth hinges. the wings and surfaces will be covered in silk. is it better to apply the hinges before or after silking?   thanks
Title: Re: cloth hinges
Post by: Dave_Trible on August 06, 2019, 06:26:02 AM
Hi Joe.  I always applied hinges first-then covered. I'd guess most did.  Try to let a minimum amount of dope or covering get into the hinge line-makes for really stiff controls.
Post by: Joe Hunt on August 06, 2019, 08:19:41 AM
 thanks, joe
Post by: Mike Griffin on August 06, 2019, 09:33:01 AM
What Ty said.  I apply hinges first.  Love Dacron hinges.
Post by: 944_Jim on August 06, 2019, 10:09:54 AM
Bear in mind I build small (1/2/A). Been sewing mine since I can't.seem to find any more Perfect or Goldberg small cloth hinge material. Where are you guys finding yours? I'm about to hit Walmart for light weight, narrow binding tape-like for old baby blankets.
Post by: Scott Richlen on August 06, 2019, 11:10:11 AM
Doesn't Morris sell the stuff?
Also, I believe there was a building hint about rubbing talcum powder into the center part of the hinge to keep paint out and to keep it flexible.
Post by: Joe Hunt on August 06, 2019, 11:30:54 AM
i'm using the light 2" polyester rib stitching tape used to cover wing rib stitches on full size airplanes. the edges are pinked so I take the wife's pinking shears and cut cross grain the width I need. I use non tauting nitrate dope to attach. joe
Post by: Mike Griffin on August 06, 2019, 12:00:09 PM
You can buy the Dacron from Aircraft Spruce.  A square yard will last for years.
Post by: Jim Hoffman on August 06, 2019, 08:13:11 PM
I use polyester taffeta when the need arises.  Available from your local fabric store
Post by: EddyR on August 08, 2019, 08:38:43 AM
 I use one pin style hinge next to the flap horn then do the rest with cloth.
This takes a lot of stress off cloth hinges
