  • July 18, 2025, 08:20:37 AM
Author Topic: Cleaning RoJett BSE .40 RE  (Read 949 times)
Offline Stephen
  • Stephen Hollier 217629
« on: September 02, 2020, 02:11:11 PM »
Looking for recommendations on how to clean the fuel gunk off my RoJett. BSE .40 engine.
Offline Reptoid
Re: Cleaning RoJett BSE .40 RE
« Reply #1 on: September 02, 2020, 02:31:05 PM »
Same way you clean any other engine. Do a search. there's hundreds of posts on how to clean engines
       Don
       AMA # 3882
Offline BillP
« Reply #2 on: September 02, 2020, 02:58:31 PM »
Straight antifreeze in a crockpot.
Bill P.
Offline dale gleason
« Reply #3 on: September 02, 2020, 04:34:33 PM »
For what it's worth....I think a barstock RoJett might suffer in appearance using a crockpot. The paperwork that comes with a new RoJett has details to keep it looking bright and shiny. (Maybe Mother's brand aluminum polish?)    dg
EDIT...I found the Bar Stock finish maintenance that comes with the motor. The big caveat is "Don't use Water". Mother's aluminum and chrome polish from auto parts stores is used with a slow turning dremel tool with a buffing tip. Caution against allowing the polish to get inside the engine.
« Last Edit: September 02, 2020, 04:54:30 PM by dale gleason »
Offline Bootlegger
« Reply #4 on: September 02, 2020, 05:44:58 PM »
 I hope that question is because you are coming  to our contest in October   #^ #^ #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Dave Harmon
  • Tulsa Glue Dobbers C/L and R/C Clubs AMA 5053
« Reply #5 on: September 02, 2020, 11:11:33 PM »
What Dale said....never use water or antifreeze in a crock pot on a BSE engine.
Tom Vieira
« Reply #6 on: September 03, 2020, 05:34:44 AM »
simple green and a brass brush work great.  and brass is softer than the aluminum, so unless you go nuts, you won't scuff the surface.  follow up with your favorite metal polish (i like blue magic) to make it sparkle.
Offline Stephen
« Reply #7 on: September 03, 2020, 10:06:10 AM »
Thanks guys for the input!!
Offline Stephen
« Reply #8 on: September 03, 2020, 10:07:25 AM »
Gil this one is my first Ro Jett I have the newer one in the plane ready for the contest :)
