  • June 20, 2025, 02:50:11 AM
Author Topic: Hawker Sea Fury  (Read 2748 times)
Mike Griffin
Hawker Sea Fury
« on: March 16, 2012, 08:02:12 AM »
Just out of curiosity, does anyone know if the Hawker Sea Fury was ever kitted?
Re: Hawker Sea Fury
« Reply #1 on: March 16, 2012, 10:42:49 AM »
Make a deal with Al Rabe to kit his and you'll see a lot of them. I'd pay 250 bucks one. Easy.
Chris...
Re: Hawker Sea Fury
« Reply #2 on: March 16, 2012, 11:52:38 AM »
Hi Mike,
AFAIK, the Sea Fury has never been kitted as a C/L stunter.  And Al's is the ultimate example of a very scale looking full stunt machine.
Top Flite does offer a stand off scale Sea Fury for R/C.
Mike Griffin
Re: Hawker Sea Fury
« Reply #3 on: March 16, 2012, 11:58:58 AM »
Hi Chris and Hi Bill
Thanks for your responses.  I was not inquiring for the purposes of doing a kit run of the design I was wanting to build one for myself if there was a kit of it or if anyone knew where I could get plans so I could build one.
Thanks for your help
Offline Pat Johnston
Re: Hawker Sea Fury
« Reply #4 on: March 16, 2012, 12:04:49 PM »
Patience...
Pat
Offline Balsa Butcher
  • High Desert Flier
Re: Hawker Sea Fury
« Reply #5 on: March 16, 2012, 12:07:59 PM »
Hmmm, put a Brodak/Pat Spitfire wing on a Brodak/Pat Jonston Bearcat fuselage and tail feathers, paint Sea-Furyish. It could work (but patience would be a better idea).  8)
Pete Cunha
Sacramento CA.
AMA 57499
Mike Griffin
Re: Hawker Sea Fury
« Reply #6 on: March 16, 2012, 01:21:57 PM »
Patience is a virtue..   y1 y1 #^ #^
Re: Hawker Sea Fury
« Reply #7 on: March 16, 2012, 01:44:02 PM »
   The one you want is the Al Rabe version for sure. You need to sweet-talk Al to get plans.
Walter Hicks
Re: Hawker Sea Fury
« Reply #8 on: March 16, 2012, 06:50:28 PM »
Would love to build one this has always been my favorite plane.
Re: Hawker Sea Fury
« Reply #9 on: March 16, 2012, 07:03:04 PM »
I have never heard that Al has ever given any one his plans for the Sea Fury. ??
Re: Hawker Sea Fury
« Reply #10 on: March 16, 2012, 09:22:59 PM »
I think i have plans for one somewhere. not Al Rabe plans....id love tlhose!!
Offline Joseph Patterson
  • AMA member- Supporter
Re: Hawker Sea Fury
« Reply #11 on: March 17, 2012, 01:45:46 AM »
     Dat Westerner did say Patience!!
          Doug
Re: Hawker Sea Fury
« Reply #12 on: March 17, 2012, 09:01:18 AM »
Too bad, I was ready to buy and build.
Chris...
Mike Griffin
Re: Hawker Sea Fury
« Reply #13 on: March 17, 2012, 10:04:41 AM »
I appreciate the thought Chris but I doubt if I will put out another kit until next year.  I have the YAK9 D coming out this summer and then I think I am going to take some time to catch up on some building projects of mine.  Al Rabe and I have swapped some e mails about the Sea Fury and I ordered the disk from Al on building it.  I want to build a prototype of it for myself before I even think about doing a kit and of course that would be something that Al would have to approve and we have not even discussed at this point...
Re: Hawker Sea Fury
« Reply #14 on: March 17, 2012, 02:44:55 PM »
I'd take a kit if you ever did one. cool looking plane!
Offline dale gleason
Re: Hawker Sea Fury
« Reply #15 on: March 17, 2012, 05:01:54 PM »
This may or may not be appropo....I had the unenviable task of  moving John Callentine's Rabe Mustang up the line in the pulltest pits. I just didn't want to mess up in any way, this is a gorgeous plane, I don't know if Al has ever seen it, but it is just unbelievable.
Anyway, I decided to lift it from beneath the fuselage in the wing center section between the "shock gear".
It has to be filled with helium. Just unbelievable! I don't know what it weighs, but it is light beyond anything that size and with that gorgeous of finish.
I had talked with John at appearance judging the day before about his plane and he mentioned he would like to build Al's Sea Fury. If anyone on the planet can build the perfect tribute to it, it is John Callentine.
And he flies it guite well, too, I'd have second thoughts about tooling around with a plane like that in less than ideal conditions.
dg
