  • July 17, 2025, 12:51:13 PM
Author Topic: Chinese 3/32nd @#$%&  (Read 2610 times)
Offline Ward Van Duzer
« on: September 03, 2010, 01:59:54 PM »
Been working on my ARC Pathfinder and decided I wasn't real happy with the horns. Some kind of corroded white metal...Anyway I order some real US horns from the Randy man. Guess what? (you already know, I'll bet...har, har!)
3/32nd of an inch is .0937. Chinese 3/32 of an inch is .0999 or something. So I'm not going to rip it's heart out to replace the BC to flap pushrod.
Does anyone know the mm equivalent of .099 so I can drill out the horn?
W.
Re: Chinese 3/32nd @#$%&
« Reply #1 on: September 03, 2010, 02:18:32 PM »
 Better yet Ward-O, drill'er out and use a ball link instead of a clevis. y1
Offline Rob Killick
« Reply #2 on: September 03, 2010, 02:27:22 PM »
Hi Ward ,
Try this ...
http://www.mrt-wheels.com/conversion%20chart.htm
A little , but not a lot of help .
Rob K.
Rob Killick , MAAC 33300
Offline Michael Boucher
« Reply #3 on: September 03, 2010, 02:46:25 PM »
.099" is equal to 2.5146 millimeters.    H^^
AMA 59633
« Reply #4 on: September 03, 2010, 02:48:25 PM »
2.5mm / (25.4 mm/inch) = 0.0984 inches.
It's gotta be 2.5mm.  Music wire seems to run a bit big, sometimes, so if the wire is nominally 2.5mm it may actually be 0.099".  Fortunately drills usually drill a bit bigger than their rated size, so a 2.5mm should work.
Can you open up the hole with a jeweler's rat-tail file?
« Reply #5 on: September 03, 2010, 03:08:17 PM »
...or you can get out your 2.5146 mm drill bit. :##
Online Dick Pacini
« Reply #6 on: September 03, 2010, 04:07:18 PM »
Ward, if you are unhappy with the product, let Brodak know.  They are good people and service oriented.
Checking over my new P40, I measured the horns and also came up with .099.  My many years in manufacturing made me realize they used 2.5 mm coated wire.
AMA 62221
Offline W.D. Roland
« Reply #7 on: September 03, 2010, 07:03:22 PM »
Harbor Freight has Metric drill bits, loose in package so mike them to be sure the right one is grabbed!
 Decent enough quality for most stuff.
David
David Roland
51336
Offline Garf
    • Hangar Flying
« Reply #8 on: September 03, 2010, 07:54:46 PM »
Try a #39 wire gage size drill bit.
Dave Adamisin
« Reply #9 on: September 03, 2010, 08:44:04 PM »
Wait a minute. The guy who sold me mine said it was the only one..............
Offline Dallas Hanna
« Reply #10 on: September 03, 2010, 11:20:00 PM »
Yep Phil.  Another good chart here.  Worth hanging on the wall.   Every modeler should have a set of number drills.
http://www.classicfasteners.com.au/TechData/letdrill.pdf
HH
Offline Geoff Goodworth
« Reply #11 on: September 04, 2010, 05:48:14 AM »
Ward, et al.
Herb's little chart is great for the shop wall but for inside, at the computer, look at a little program called Versaverter.
« Reply #12 on: September 04, 2010, 07:09:45 AM »
Ah, rocket scientists, guitar players, and machinists...
Thanks troops!
W.
« Reply #13 on: September 04, 2010, 09:07:59 AM »
This my local chop,
http://www.metricsunlimited.com/
Metrics Unlimited.
Bolts, nuts, drills, you name it.
English, French, numbered, SWG, conversion charts,,,,
Take in a stange fastener and they'll ID it and have some in stock.
I wouldn't worry about that 3rd decimal accurarcy stuff, unless you're fitting a piston.
« Reply #14 on: September 04, 2010, 10:28:35 AM »
Why dril out the horn if using ball links?  I have been tapping mine for what ever machine screw the ball link has.  Using sockets heads screwed into the horn and a locking nut makes for a solid connection.   H^^
« Reply #15 on: September 04, 2010, 01:15:42 PM »
The pushrod coming off the BC had a 90 degree bend at the flap horn. Didn't want to make a MaGilla  HB~> out of this thing so a 10 minute trip to ACE is the place and 3 bucks for a # 40 (Chinese 3/32nd) drill and I'm back in business. Yes Doc, the elevator horn will be a threaded ball link!
Tanks all.... :D
Ward-O
