  • June 28, 2025, 06:18:53 AM
Author Topic: Dubro Filling Station  (Read 982 times)
Offline Jay Wood
« on: July 24, 2009, 12:44:23 PM »
Can anyone suggest a safe chemical to run through a Dubro filling station to clean out a "gunky" pump?
Offline Richard Grogan
Re: Dubro Filling Station
« Reply #1 on: July 24, 2009, 12:49:47 PM »
I would think 91% isopropyl alcohol would do the trick. Just be sure to pump fresh fuel though it after its cleaned out.You don't want any rubber(if any) to get dried out and crack.
Long Live the CL Crowd!
                  AMA 85745
Offline Steve Scott
« Reply #2 on: July 25, 2009, 11:40:42 AM »
I had a couple of brass NVA w/steel needles that were all gunked up with castor residue.  I got the bright idea to soak them in a small jar of "rubbing" alcohol.  Rusted the assemblies up solid.  A 91% solution of isopropyl alcohol is going to be 9% water?
Offline Pinecone
« Reply #3 on: July 26, 2009, 06:46:42 AM »
Fuel should clean out the pump perfectly.  If you have some old fuel that you aren't comfortable in flying, that would be a good use for it.
Terry Carraway
AMA 47402
