  • June 24, 2025, 05:25:14 PM
Author Topic: Changing Nitro  (Read 1586 times)
Changing Nitro
« on: September 23, 2019, 09:27:42 PM »
blank
« Last Edit: August 30, 2021, 09:05:35 AM by Motorman »
Re: Changing Nitro
« Reply #1 on: September 24, 2019, 12:03:01 AM »
First case: there's the same amount of nitro before and after.  100*.2 = (100 + x)*.15
20 = 15 + .15*x
5 = .15*x
5/.15 = x
33.3 = x
Second case: Add the quantities of nitro.  .1*100 + .2*x = .15*(100 + x)
10 + .2*x = 15 + .15*x
.2*x = 5 + .15*x
.05*x = 5
x = 5/.05
x =100
Online Dave Harmon
Re: Changing Nitro
« Reply #2 on: September 24, 2019, 12:12:53 PM »
First case add 33.3 cc
second case mix 1/2 and 1/2
Right?
Yes
Offline 944_Jim
Re: Changing Nitro
« Reply #3 on: September 24, 2019, 04:15:55 PM »
MM,
Here is your very own copy:
http://web2.murraystate.edu/andy.batts/ps/fuel.htm
Grab the Excel spreadsheet. It is built for quarts if I remember right. I saved it and edited it for 8 ounce batches.
Enjoy!
Offline Richard Imhoff
Re: Changing Nitro
« Reply #4 on: September 24, 2019, 07:55:28 PM »
Try this site it's where I go to figure when I want to add oil or nitro or mix complete batches.
http://nitrorc.com/fuelws/
Dick Imhoff  AMA 58502
Combat, Racing, Stunt, and big time fun flyer, and Maybe a bit of carrier.
Offline 944_Jim
Re: Changing Nitro
« Reply #5 on: September 25, 2019, 03:04:24 PM »
MM,
Did you get a chance to try the spreadsheet? It is straight up for what you intend to do...mix two fuels and see results.
Re: Changing Nitro
« Reply #6 on: September 25, 2019, 06:30:29 PM »
Go here it's the best I have ever found
Offline 944_Jim
Re: Changing Nitro
« Reply #7 on: September 25, 2019, 06:55:29 PM »
MM,
Shoot a pm with email/phone number. I'll talk you through it. Since you do the smalls (I've seen you on CEF), I'll pass the altered smaller (8 oz) calculator to you. Five minutes will be all it takes.
I'm really busy at work, so it may be this weekend. Saturday mid-day ok? I'm in Central time.
Offline RogerGreene
Re: Changing Nitro
« Reply #8 on: September 25, 2019, 09:06:40 PM »
Attached is an spreadsheet I use for changing store bought fuel with high nitro% and low oil% content. So by adding castor oil you can change the nitro content.
Enjoy,
Roger Greene
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
