  • June 26, 2025, 04:12:07 AM
Author Topic: Making CF landing gear  (Read 2041 times)
Offline pipemakermike
« on: November 24, 2009, 05:50:34 AM »
Can anyone point me at a tutorial please - I am sure that there was one posted in the last couple of years but I cant find i
Mike Nelson
Offline George
  • Love people, Use things.
Re: Making CF landing gear
« Reply #1 on: November 24, 2009, 08:41:44 AM »
Have you checked with Windy Urtnowsky? Windy has videos on EVERYTHING.
   http://windyurtnowski.com/
Also, made a quick check and found:
Dan Winship -  http://winshiprc.tripod.com/carbon_fiber_composites.htm
George
Edit: That's Dan not Dave...sorry Dan.
« Last Edit: November 24, 2009, 07:54:26 PM by George Bain »
George Bain
AMA 23454
« Reply #2 on: November 24, 2009, 11:50:01 AM »
I thought that Dan used to have a step by step outline, but I can't find it now.
Offline Bill Ervin
« Reply #3 on: November 24, 2009, 03:24:52 PM »
Hey Mike, don't you mean undercarriage?
http://cstsales.com/tutorials/carbonundercarriage.pdf
« Reply #4 on: November 24, 2009, 04:28:59 PM »
They sure make it look simple enough.  But, as they say the materials is the cost factor.
« Reply #5 on: November 25, 2009, 04:18:28 AM »
Thanks Bill, that was the article that I remembered (or at least one like it)
landing gear vs undercarriage  Just another example of 2 nations separated by a common language <G>
Mike Nelson
Offline dale gleason
« Reply #6 on: November 25, 2009, 09:16:04 AM »
In a previous life, I had the pleasure to fly the Vickers Viscount, lovingly referred to by some as the "Redcoat's Revenge". The gear "switch", changed to a "lever" was labeled, "Chassis". The propeller gov'ner had both "flight fine" and "ground fine" for pitch selections.
dg
Offline Matt Colan
« Reply #7 on: November 25, 2009, 10:14:02 AM »
Windy sells the DVD on making CF landing gear for $15.
« Reply #8 on: November 25, 2009, 03:36:17 PM »
Once you have the materials, it's not very expensive per unit. But a roll of carbon fiber cloth, carbon tow, epoxy, plywood for forms, molding material like Tap Plasitics Qwik Cast or similar and mold release wax or PVA release can get pricey (to say nothing of my very cool, but very cheap, home made post cure oven). The actual cost of the gear per unit is not much, but accumulating the supplies can get up there.
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #9 on: November 25, 2009, 04:55:47 PM »
What a fine tutorial! Wonder if CST has any more (free ones)?
L.
"If the creator had a purpose in equipping us with a neck, he surely meant us to stick
it out." -Arthur Koestler
Offline Bill Ervin
« Reply #10 on: November 25, 2009, 05:35:44 PM »
No need to wonder Larry, your wish is my command!
http://cstsales.com/tutorials.html
Offline John Sunderland
« Reply #11 on: November 27, 2009, 08:08:37 PM »
Actually, I would be interested in finding someone to do protos of CF gear for a few semi-scale birds I had
in mind! :P
