  • July 05, 2025, 10:05:57 PM
Author Topic: CF landing gear  (Read 2733 times)
Offline Scott B. Riese
  • Just a student of stunt
CF landing gear
« on: August 14, 2008, 10:15:10 PM »
Hello all. I'm in the middle of making a profile Impact. 650sq 40vf-pipe. Here's my question. WHO'm is making Profile carbon fiber landing gear?  H^^
Scott (back testing the waters) Riese
Scott Riese
Portland, Oregon
AMA 528301
Offline Ralph Wenzel (d)
Re: CF landing gear
« Reply #1 on: August 14, 2008, 10:40:03 PM »
Will these do?
http://2dogrc.com/ecommerce/os/catalog/index.php?cPath=120_129
Also found several articles on "rolling your own" . . .
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Re: CF landing gear
« Reply #2 on: August 14, 2008, 10:44:22 PM »
WOW.There really is a GOD!!
Scott Riese
Portland, Oregon
AMA 528301
Re: CF landing gear
« Reply #3 on: August 15, 2008, 05:16:52 AM »
Perhaps. However, last night, "Google Rules"!!!
Ralph Wenzel
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: CF landing gear
« Reply #4 on: August 15, 2008, 08:32:43 AM »
My experience with CF gear on a profile has been less than satisfactory.. I do not crash very often, still have the first airplane I built when I returned to the hobby and every one since.. Lucky I guess.. but anyway..
When I built my Ringmaster 576 I used CF gear like the ones in the link.. Great... light weight and seemed really strong.. Problem surfaced when I had a less than perfect landing last week.. The gear split where the bolts went through at the top that held it to the fuselage. This was a landing that wire gear would have simply laughed at, if this would have happened at a contest I would have been out of business unless I had a spare set of gear all pre-drilled and ready to bolt on.
If you look at the CF profile gear you will see the CF strands run vertical and like wood splitting with the grain it doesn't take much force in the wrong direction to make it split. Now think about this mounted on a profile. Allot of force is applied at right angles to the CF strands and the only thing keeping it from splitting is the strength of the epoxy..
I am going to attempt to repair my split gear by wrapping CF tape around the mount part with epoxy and re-drilling the holes. Wondering if it wouldn't be a good idea to do this with new gear before the holes are drilled...
Offline Don Curry AMA 267060
Re: CF landing gear
« Reply #5 on: August 15, 2008, 09:14:56 AM »
How about roughing up the c/f gear with sand paper and wrapping the mount portion with kevlar thread like used in the pull/pull rudder system on r/c planes. then soak in thin ca?
Offline Bob Reeves
Re: CF landing gear
« Reply #6 on: August 15, 2008, 10:25:24 AM »
My only objection to kevlar is it would need to be painted black to match the CF or in my mind it would look icky. I would love to use CA when I attempt to repair the gear I broke but don't know enough to know if it would be strong enough. Even thinking all I have is the run of the mill model shop epoxy and not sure it would be any better than CA.. I'm sure not going to order $60.00 worth of some high dollar epoxy to fix a $30.00 - $40.00 landing gear..
Offline catdaddy
  • catdaddy
  • The Dude Abides
    • Tulsa Gluedobber Control Line Club
Re: CF landing gear
« Reply #7 on: August 15, 2008, 11:58:08 AM »
Will these do?
Ralph
How would you mount these on a profile? They don't look like they would work. They look 90deg off to me.
regards,
Rick"catdaddy"Blankenship
Offline Bob Reeves
Re: CF landing gear
« Reply #8 on: August 15, 2008, 01:18:48 PM »
Took another look and ya from the pictures one end needs to be bent the other direction.... These are for mounting on the bottom of a built up fuselage..
Offline Bill Adair
  • AMA 182626
Re: CF landing gear
« Reply #9 on: August 15, 2008, 01:36:37 PM »
Bob,
Would mounting straps work better than drilling the mounts? Seems like drilling holes in them would weaken them a bit.
Re: CF landing gear
« Reply #10 on: August 15, 2008, 01:52:31 PM »
OK, I think y'all are correct. I had looked only at the top pair and it the "left" segment were bolted to the fuselage, and if the "right" segment were circular (like an axle) . . .
OK, back to the "How to Make CF L/G" part - - See:
http://www.gsal.org/articles/building/cfgear.html
http://findarticles.com/p/articles/mi_qa3819/is_200002/ai_n8896684
Also, I'm pretty sure that Mike Pratt made CF L/G for the Primary Force; I bet he could tool up for something larger if there were sufficient demand.
I believe Darrell Winship also makes CF L/G to order.
Or call Windy!
Ralph
Ralph Wenzel
Offline Rudy Taube
  • Ret Flyboy
Re: CF landing gear
« Reply #11 on: August 15, 2008, 03:52:25 PM »
Hi Scott,
Here is a link for CF profile gear that should fit our CL planes. It is for a .40 size Profile Fun Fly RC plane. These planes usually weigh around 4 lbs. ... The Profile LG is about 1/2 way down the page, it is # CLG 180. They are out of stock right now, but they replenish regularly.
I have never used their small gear, but I have used their larger gear on my 30 lb. planes (I told you guys I build "heavy" ;-). TNT are great people to deal with. They also make very nice aluminium gear for Profiles and all other type and size models. Call them and I am sure they can set you up.
Rudy
AMA 1667
Offline catdaddy
  • catdaddy
  • The Dude Abides
Re: CF landing gear
« Reply #12 on: August 15, 2008, 04:01:13 PM »
Hi Scott,
Where's the link?
regards,
Re: CF landing gear
« Reply #13 on: August 15, 2008, 04:29:24 PM »
Still no link.Thanks for all of the advise.
Scott Riese
Portland, Oregon
AMA 528301
Re: CF landing gear
« Reply #14 on: August 15, 2008, 05:19:33 PM »
I found it - - See:  http://www.tntlandinggear.com/store/shop/composite_landing_gear.htm
Unfortunately, it says, "Out of stock" . . .
Ralph
Ralph Wenzel
Offline Rudy Taube
  • Ret Flyboy
Re: CF landing gear
« Reply #15 on: August 15, 2008, 07:40:31 PM »
Thanks for the "save" Ralph.  H^^
YIKES! .... Sorry guys, I had it in "copy" but forgot to "paste".  n~
This being over 50 stuff is a PIA!  HB~>
TNT is a very good co., they have been helping us modelers for decades. Call them and they will let you know when they will have them back in stock. They make/sell quality products.
Rudy
AMA 1667
Re: CF landing gear
« Reply #16 on: August 17, 2008, 10:47:19 PM »
I think Windy sells a CF profile LG for the P.Cardinal. RandyS. might also sell a profile gear...he has a bunch. I think it's overkill, myself. 'Lunimum works fine. Use the SIG Fazer gear!  n~ Steve
Offline Leo Mehl
Re: CF landing gear
« Reply #17 on: August 19, 2008, 02:38:25 PM »
Naw Go for the cabon Fibre, it has no return memory like aluminum does. I found that out on my Gieske Bear that only gets 23 point squares. HB~> HB~>
