  • July 17, 2025, 11:39:22 PM
Author Topic: Sealer for Brodak ARF film?  (Read 795 times)
Offline peabody
« on: August 05, 2021, 07:04:15 PM »
Is there a sealer that can seal the seams of Brodak film that is used on ARFs?
I have tried the monocoat sealer to no avail.....
Thinner dope?
TIA
Peabody
Re: Sealer for Brodak ARF film?
« Reply #1 on: August 05, 2021, 07:32:46 PM »
  Monokote Trim Cement, if it is still available, or brush some thinned Balsa-Rite or SIG Stix-It under the loose edges and seal down.
Offline Bill Barber
« Reply #2 on: August 05, 2021, 07:50:05 PM »
 I have used thinned 5 minute epoxy to seal edges.
                 Bill Barber
AMA 325076
Offline Phil Spillman
« Reply #3 on: August 09, 2021, 08:20:02 AM »
Hi Rich, A mixture of 50% Fletch Glue, the stuff used to mount feathers and such on arrows, and MEK or substitute, has worked for me. Apply with a q tip.
Phil Spillman
Phil Spillman
Offline Kim Doherty
« Reply #4 on: August 09, 2021, 10:44:28 AM »
Reducer wiped into the edge will reactivate the adhesive. I use reducer to apply all of my trim film. Note: only work small areas at a time as you have about ten seconds to press it down.
Kim
