  • July 06, 2025, 03:29:58 AM
Author Topic: Bi Slob balance point  (Read 2167 times)
Offline Bill Hodges
« on: May 29, 2008, 04:51:35 PM »
Guys, I am just finishing up a Brodak ARC Bi Slob.  I have searched the instruction book from front to back and can find no mention of the balance point.  Right now, it is balancing dead on the spar.  Is that a good jumping off point or do I need to make some adjustment before the first flight?  Any help will be appreciated.
Bill Hodges
Bill Hodges
AMA 12450
Re: Bi Slob balance point
« Reply #1 on: May 29, 2008, 08:13:06 PM »
You mean there's supposed to be a balance point?   ;D  I don't know that I can even say Bi-Slobs require any kind of trim... hmm...
Offline Allan Perret
  • Proverbs
« Reply #2 on: May 29, 2008, 08:42:03 PM »
You are good to go on the spar..
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Roger Vizioli
  • CLiner
« Reply #3 on: May 30, 2008, 06:29:50 PM »
Bill,
Checked three of them from our club.
Spar seems to be the preferred (or just happens to be  y1) location.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Bill Hodges
« Reply #4 on: May 31, 2008, 08:38:21 AM »
Thanks for the info guys.  Maybe I can get a flight on it soon.
Bill Hodges
AMA 12450
Offline Clancy Arnold
« Reply #5 on: June 01, 2008, 06:53:55 AM »
Which spar???
Upper or lower wing???
Clancy
Clancy Arnold
U/Tronics Control
  • CLiner
« Reply #6 on: June 01, 2008, 10:08:06 AM »
Which spar??? Lower
Upper or lower wing??? Upper
That's the balance point on ours. your results may vary!    Roger
Clancy
Roger Vizioli
AMA L-2408
Florida/Space Coast
  • Proverbs
« Reply #7 on: June 03, 2008, 06:46:30 AM »
I just rechecked mine.  Its about 1/2" fwd of spar on upper wing.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #8 on: June 03, 2008, 07:25:44 AM »
I just pulled out the plans that where in Fling Models and it is 1/2" behind center of the spar. I don't know if thats where everyone is flying them at that but thats what the plans say.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
