  • July 15, 2025, 12:56:45 PM
Author Topic: Carbon fibre pushrod ends  (Read 7318 times)
Offline Mike Quinn
« on: February 10, 2025, 03:23:08 PM »
Hi
Anyone think this is a bad idea for 6mm OD / 4mm ID carbon pushrods.
Aluminium (6061) taped 3mm x 25mm.  Turned down on lathe.  3mm threaded rod JBWeld glued/threaded into Ali insert then the insert JBWelded into roughed up (internally) carbon tube.
Degreased at every stage.
Outside of tube bound with Kevlar thread and heat shrinked.
I reckon should be good for 46 sized models.
Banana skins ?
Cheers
Offline Mike Quinn
Re: Carbon fibre pushrod ends
« Reply #1 on: February 10, 2025, 03:33:47 PM »
Picture problems 😀
« Reply #2 on: February 10, 2025, 05:25:17 PM »
IMHO - I am not metal expert by any stretch of the imagination but looks like it should work. As Sparky says TLAR. That looks about right.
My only suggestion would be to shorten the length of the threaded rod so it might put let leverage on the stress riser at the ball joint if that makes sense.
Good luck.
Offline Jim Hoffman
« Reply #3 on: February 10, 2025, 06:41:27 PM »
I recommend that you put grooves into your metal rod to give the JB weld something to anchor onto.  Further, I would NOT use aluminum.
Central Hobbies www.centralhobbies.com  sells excellent fittings of steel and titanium to do exactly what you are trying to do.  Theirs have grooves at the CF attached point.
I do not have experience with aluminum as the pushrod material; only steel, titanium and music wire.
I’ve built dozens of CF pushrods and have hundreds (thousands?) of flights with success.
Below is what I do when I attached a simple L bend music wire end fitting to a CF tube.  The copper wire is soldered to the music wire.  I spin the soldered assy and use a file to achieve a nice slip fit into the CF tube.  Clean everything and assemble with JB Weld
« Last Edit: February 10, 2025, 08:00:38 PM by Jim Hoffman »
« Reply #4 on: February 10, 2025, 07:51:50 PM »
After reading Jim’s post I think he is correct.
That control system is the heart of the plane. Doesn’t skimp. 🤓
« Reply #5 on: February 10, 2025, 09:22:13 PM »
Mike your system looks sound. I would rough the insert with 60 grit then clean with acetone. I tape a little piece of fine sand paper to music wire and spin it in the ID of the tube. Definitly glue the stud in and you could file a small flat on the threads for anti rotation. You can do everything and your kevlar thread with the same batch of JB Weld.
MM :)
Offline Mike Quinn
« Reply #6 on: February 10, 2025, 11:35:24 PM »
Hi Jim
Ive used ends like the Central Hobbies ones before.  I sourced them from OkieAir a number of years ago.
Unfortunately, being in the UK I woukd need a small mortgage to get them posted here :)
It was really a threaded end I wanted to achieve, for use with the balll links.
Online Dave Harmon
« Reply #7 on: February 10, 2025, 11:58:41 PM »
Mike....what I and others have been doing for quite awhile now is to grind a slot lengthwise on a fully threaded rod then epoxy or JB Weld the rod into the CF tube....no aluminum insert or fittings.
The slot is only on the threaded rod that goes inside the CF rod.
Then...instead of thread I use aluminum tubing to eliminate the CF tube from splitting...easier and don't have to find the thread.
Epoxy the aluminum tube as well.
As Paul mentioned....the threaded rod is much too long....you can shorten it up just so the link will have full depth adjustment.
« Reply #8 on: February 11, 2025, 01:16:29 AM »
Mike,
There is nothing wrong with your approach, so it comes down to the quality of execution and the details. Let me throw out some thoughts in perhaps random order to consider. Then guys can throw rocks at it if they feel the need. There are lots of ways to accomplish things that work. What works for some won't work for others because they don't have the tools, or can't get the right materials so they substitute, or they insist on doing something with glue that isn't a good idea. That kind of thing.
1. The pushrod is not going to lift a battleship. There is only so much axial force your plane can generate in that pushrod. So, the trick is to have sufficient design margin above that amount and not add any more weight above that. If you don't know the actual loads it will see, then you use tribal knowledge (or Sparky's TLAR) and hope for the best. Tribal knowledge tends to make things bigger/stronger/heavier over time because no one wants to lose a nice plane due to control failure. So, I occasionally see a 3/8" diameter carbon pushrods with really thick walls, and....
2. Most of the pushrod failures that have been documented on Stunthanger that I can recall have not been due to axial quasi-static overload failures. The ones I am thinking about were fatigue failures, and just changing fittings to titanium does not necessarily make those go away. And related, Paul's point I believe was that minimizing the "stick out" of your threaded stud reduces the bending moment from lateral loads (static and dynamic) on the threads right where the stud enters your aluminum threaded bushing. That is a very good idea. Let the carbon do what it is good at. One thing I would be absolutely sure of is that your threaded rod has rolled threads, not cut threads.
3. There is nothing inherently wrong with using aluminum against the steel threaded rod as long as the contact pressure is below the galling pressure for that combination. Personally, I would install the stud in the bushing using Loctite and then install a jam nut on the stud. And use an appropriate torque. I like that your bushing is long and you can get a lot of threads engaged. Know that all threaded interfaces deform to allow load-sharing. In other words, the stud will stretch if you put a jam nut on it and cinch it up to stabilize the joint. (All proper bolted joints stretch the fasteners. They are supposed to.) If you don't like the jam nut idea, then you are going to need Loctite and you may have bigger issues with fatigue.
4. Using 6061 aluminum for the bushing is good, but to know that it is suitable you also need to know the temper. You don't want soft, gummy and low yield strength. Condition T6 is excellent.
5. Shear/tearout of the aluminum threads is pretty unlikely from actual use due to the plane not likely creating huge forces in the controls. If you have 8 or more full threads engaged you should be golden. With four or five you would probably "get by," but why not increase your margin for a fraction of a gram?
6. Note that with your shouldered bushing, if it is bonded in contact with the end of the carbon tube it can't go anywhere when the pushrod is under compression even if the bondline failed. So your bondline isn't really even loaded when the unit is in compression.
7. The regular JB Weld is a surprisingly good adhesive for a consumer grade material. I tested some side-by-side with aerospace epoxies for fun years ago for a government project. However, bonding techniques are critical. Cleanliness and proper solvents are critical. Wetout is critical. You don't want any residue left by your cleaning process. Straight acetone is good. Cleaned several times. The issue with bonding aluminum is that it instantaneously starts building an oxide layer when it is cut. The oxides do not improve your bond. For best results, sand it off and do multiple acetone wipes. (You can scrub the oxides off of larger aluminum joints with Ajax cleanser and water, which works well, then rinse thoroughly with water and check for "water break free" conditions. That tells you it is clean enough.) You can use a bit of heat and then apply adhesive all over the contact area. Do the same to the inside of the carbon tube. Wet everything with adhesive that you expect to stick. Now push the parts together, use heat to control viscosity and material flow as needed. Wipe clean. Air cure. Epoxy does not develop full strength for about 5-7 days, no matter what it says on the bottles. At colder temps, the full-cured strength will be less. Letting it cure until it seems "pretty hard" and then post-curing at higher temps will get you the max strength that the epoxy is capable of. For aerospace materials, the manufacturer will tell you what these cure schedules look like. Think time/temperature charts. For a lot of epoxies to get to their quoted strength you might need an hour or two at around 120F? You would need the data sheet to be exact. That said, JB Weld with just a room temp cure for the geometry you are showing with a well-prepared joint should exceed any tension loads your pushrod will ever see.
8. Another way to look at this is which part in the loadpath is the weakest? Will the threads pull out of the Delrin rod end before they pull out of the aluminum? Will the bond joint fail in tension before the Delrin? Will the 3mm threaded rod fail first? Will the surrounding material of the ball socket fail before any of these? All things that can be calculated or tested, but hey, this is just a hobby and maybe tribal knowledge is good enough?
9. It never hurts to score or "rough up" the two bonding surfaces unless that damages/reduces their own structural integrity. In this case, no. But mostly it just breaks up any cleanliness issues on the surfaces. It does also act as a failsafe should your glueline fail, since it keeps the bushing locked into the tube. But if done right, the glueline will not have an adhesive failure, and so rings and gouges and spiral grooves aren't necessary except for easier adhesive application and venting. But I do it also because it costs little to do the extra prep in case I somehow contaminated the joint and didn't realize it. It has happened to some of the best. (aka the "fried chicken incident.")
10. Epoxy joints are strongest when the bondline thickness is controlled. In a metal-filled epoxy you might think this is already done for you. I don't know their particle size, but it is likely very small and not too helpful. Most epoxies I have used will do best with a .002 to .010 inch bond line. It leaves room for the epoxy. It also helps provide some temperature compensation for dissimilar materials like your carbon and aluminum. Probably not too severe a case here since your plane (hopefully) will not see large swings in storage temperature?
11. Failure analysis of a bondline starts by determining the type of failure. A cohesive failure is when the glue is still sticking to both sides of the joint, but the bonding material has sheared between the two surfaces. That means your prep was good or very good, but the adhesive didn't live up to the loads placed on the joint. An adhesive failure is when the glue comes off the parts clean, usually predominantly on one side and the bulk of the glue stays stuck to the other side. That means the joint prep was inadequate or the wetout of the adhesive on the parts was not done quickly enough, or the material was too old, etc.  Most of the time, a failed joint will be a combination of adhesive and cohesive failure. If there is a pattern of total adhesive failures then the training, tools, or materials are lacking. To figure that out you have to watch the process. By watching, you can usually figure this out pretty quickly. I worked with a guy who worked on the Grumman American light plane that first used a FAA certified process for bonding primary structure out of aluminum. It was a rigorous development, but seems to have been robust.
Just a few thoughts and some rationale behind them. But modelers have their special methods that they learn to trust and their reasons for doing things that way. But I don't see anything fundamentally wrong with your approach. So it comes down to the little details in actual execution.
« Last Edit: February 11, 2025, 01:38:56 AM by Dave Hull »
Online Lauri Malila
« Reply #9 on: February 11, 2025, 09:18:37 AM »
For 100% peace of mind, a very easy thing to do is to drill a short ø1-1,5mm radial hole through the carbon tube and into the aluminium insert but not in the thread. Somewhere like half way of the lenght of insert.
Glue in the hole a small piece of piano wire, grind flush with the surface and wrap/bush to stop it from coming out. L
« Reply #10 on: February 11, 2025, 05:47:15 PM »
You can do the same with all thread, you just need a very small drill and a steady hand with the drill or press.  It ain't coming out(.)  You still need the wrap or collar.  That is for splitting.
« Reply #11 on: February 11, 2025, 08:11:06 PM »
We've been taught not to use aluminum with carbon: they have way different thermal expansion, and they are far apart on the galvanic corrosion scale.  These may not be big deals for a joint that doesn't vary much in temperature and that stays dry, but I use titanium rod ends from Central Hobbies to be safe.  They work fine.
Online Lauri Malila
« Reply #12 on: February 11, 2025, 08:19:13 PM »
Another question is how many of those so called carbon tubes are actually carbon and not dyed glassfiber.
Easton (?) makes really nice alu-carbon arrowshafts, they are great pushrods. L
Offline Mike Quinn
« Reply #14 on: February 11, 2025, 11:58:41 PM »
Hi
Thanks for the info.  Definitely food for thought.
Its only for learning to fly with Cardinal type models so I figure the ground will get in the way long before I need to worry about anything else 😂
PS Howard, if you want to post a bunch of those fittings to me in the UK I’m all ears 😀
« Reply #15 on: February 12, 2025, 06:34:46 AM »
 I have been successful finding RC car and Helicopter turnbuckle fittings of all sizes that make great pushrod ends and have the hex adjustment in the center and opposing threads.  Some come with jam nuts which are nice only if you have access.  Steel which are fine for electric and Titanium for IC and most are metric.
Still after looking at your original post, I see nothing wrong with what you are doing.  I would pin the sleeve as has been discussed and, since you will have a metal-to-metal connection, I would use jam nuts.  Be aware that this connection will require you to remove the ball link from the horn to adjust it unless you plan on making an opposing thread version on the other end.  However, if you replace your all thread with an opposing thread turnbuckle you can make all adjustments at one end without removing the ball link.  Personally, I don't like movement in ball links that I cannot access but that is just me.
« Last Edit: February 12, 2025, 06:55:18 AM by Ken Culbertson »
« Reply #16 on: February 12, 2025, 07:08:53 AM »
Get a long 4-40 bolt, cut off it's head, roughen about half of it (the end that head was cut off) with dremel cut-off wheel, sand inside of carbon fiber tube (not longitudinal motion, but rotational motion), clean everything with acetone, J-B weld together, over-wrap end with thread and epoxy.
Offline Mike Quinn
« Reply #17 on: February 12, 2025, 09:27:34 AM »
Hi Ken
Indeed I don’t know why I didn't think of turnbuckles straight off.  Ive used them a number of times on RC slope soarers and F3A models.  I’ll have a look.
Looking at the Ali arrow shafts as Easton shafts are available in UK.
Cheers
« Reply #18 on: February 12, 2025, 12:19:01 PM »
The Trouble and I have been contemplating going to a contest there. If so, I’ll take you some.
Offline Brian Hampton
« Reply #19 on: February 12, 2025, 07:22:19 PM »
I did the same back in about '08 when I was designing my own model using the ball joints and turnbuckles from an RC car. Pushrods were CF arrow shafts which have an alloy core inside them. Because the turnbuckles cut their own threads into the ball joints the left hand thread was used into the ball joint and length trimmed so the adjustment hex had only about 1/8" to keep any possible bending forces to a minimum. The car ball joints have way too much friction so I packed the slots with tiny spring washers and set the adjustment screw until they would just barely fall under their own weight. At the pushrod end I turned up a light push fit from alloy bar stock around 1/2" long then drilled and tapped the thread to suit the turn buckle which then had a nylock nut fitted in reverse so that once again the locking nut only left a similar 1/8 " adjustment against the hex to limit any bending forces. That must be enough details for the ball joint stuff.
However the bell crank and drive to the push rods was somewhat different so I've added a photo to best explain. The bellcrank itself is in the normal place in the centre of the wing but it's support rod is firmly attached to the bellcrank so the rod rotates with the bellcrank. The lower end of the rod protrudes through the bottom of the wing and attached to that is another bellcrank set at 90 degrees to the main bellcrank but with two ball joint slots for both flap and elevator push rods. That allows for seperate and independent adjustment of both flap and elevator travel as well as adjusting for zero flap/elevator settings. On initial flights I made another attachment to the flap ball joint connection to set the ball joint directly above its centre of rotation so the flap would have no movement, in other words fly like a flapless model so I could play with elevator only travel to get what felt to me like the the best feel in hard turns. When I was satisfied with the elevator I then started using the flaps, after removing the extra attachment, but starting with the smallest possible movement the slot allowed. Flying flappless I'd noticed a trace of a stall at the last turn of the hourglass which was still there, although slightly less, at the smallest flap setting so I gradually increased flap movement until the stall completely disappeared. One thing I'd noticed, and which completely surprised me, was that even at the smallest flap travel the load at the handle in tight turns was much higher than flapless. The more flap travel the higher the handle loads. To sum it all up, I ended up with 17 degrees of elevator and 5 degrees of flap which of course only applies to my own design.
Offline Istvan Travnik
« Reply #20 on: March 08, 2025, 05:47:24 AM »
Keep it simple, as possible!
6 X 4 mm carbon pushrod is ideal (maybe 7 x 4 ) with M5 thread in the end.
And some plastic (ZX 100 or Nylon, Delrin, or Phenolic, with M5 thread. Connecting part is "tongue" or "fork".
https://stunthanger.com/smf/index.php?action=dlattach;topic=29045.0;attach=153618;image
https://stunthanger.com/smf/index.php?action=dlattach;topic=29045.0;attach=347442;image
https://stunthanger.com/smf/index.php?action=dlattach;topic=29045.0;attach=347444;image
Istvan
« Reply #21 on: March 08, 2025, 12:37:17 PM »
I am exploring the benefits of the double bellcrank idea.  Primarily, all adjustments can be in one place and if you route your controls out of the bottom of the wing you can have everything adjustable through a hatch and if properly setup you can increase leverage.  Right now I am using your idea to control a canard.  What your setup does is totally eliminate the need for an adjustable elevator horn and it's "PITA" access hatch.  The plane in the picture uses a fully adjustable flap "double horn" similar to Igor's and I have not had to touch the elevator with many ratio changes in four years.  But that is not why I replied:
The pictures are for the Spades.  The reduction in handle force with these on is amazing.  The ones shown are the test set and can be made much more attractive.  They can go on either side.  I left mine on top.  Mark Wood designed these for me, they are a byproduct of his work with full size aerobatic planes.  I was quite skeptical until I put them on last year.  They are not coming off.
Online Paul Wescott
« Reply #22 on: March 08, 2025, 04:20:54 PM »
Ken, The Spades need to be in their very own post, not buried in this one.  Those are amazing!  I can’t wait to see / read more…
« Reply #23 on: March 08, 2025, 09:02:30 PM »
Paul, search "spades" for the entire forum.  Quite a bit there including Mark's analysis that got me interested in trying them.  Mark knows quite a bit about aerodynamics.
