  • July 26, 2025, 02:34:15 AM
Author Topic: First layup  (Read 1992 times)
Offline RC Storick
First layup
« on: May 05, 2014, 11:08:41 AM »
Today is the first lay up of the wheel pants. They are a true composit layup. 1/2 glass, CF vial then 3/4 oz cloth. Set into a bag with parting cloth and a absorbent mat.
« Last Edit: May 05, 2014, 11:33:39 AM by Robert Storick »
Offline jose modesto
Re: First layup
« Reply #1 on: May 05, 2014, 02:04:29 PM »
Robert what's the white material in mold. Is it breather cloth directly on glass cloth.
The vacuum tube should be attached to breather cloth for even distribution of pressure.
I will send photo.
Robert are you using any heat to cure epoxy ???
Jose Modesto
Offline RC Storick
Re: First layup
« Reply #2 on: May 05, 2014, 02:06:14 PM »
I will send photo.
Jose Modesto
Peel ply on first then breather cloth. No heat. its Ezlam epoxy resin. Trust me it is even.
Re: First layup
« Reply #3 on: May 05, 2014, 02:21:38 PM »
Great. You should extend the breather cloth to the vacuum tube. You will get even preasue.
BTW you ger additional cut off switches???
jose Modesto
Offline RC Storick
Re: First layup
« Reply #4 on: May 05, 2014, 02:55:22 PM »
Not yet on the armsits. Should be this week Those two black bent bars are for 1/3 scale Extra RC tail wheels mounts at $50.00 each. He set his own price. That's where the money is!
Offline Douglas Ames
Re: First layup
« Reply #5 on: May 06, 2014, 01:27:17 AM »
We use the same technique in the Airlines for bonded repairs to flight controls and fairings.
We also use heating pads depending on ambient temp. and size.
A heat lamp would work on a project this small.
AMA 656546
Offline RC Storick
Re: First layup
« Reply #6 on: May 06, 2014, 05:58:12 AM »
Well the first wheel pant out of the mold had some flaws. The mold is a virgin mold and some of the paint came off onto the pant. Other than that the prototype is a success! It weighs 7 grams. I use to think $50.00 for a set of wheel pants was high. Try making some and you will get a grasp on what it is really worth. I was going to try to produce these but they will be only made on a prepaid basis and I will only do a few. There is a ton of work that goes into these.
So today I will fix this mold and do another one. But first its off to the field.
Offline Sean McEntee
Re: First layup
« Reply #7 on: May 06, 2014, 09:08:13 AM »
Is this the only shape/type you will have available?  IOW could you do a custom order if I had a obscure shaped pant?
Offline RC Storick
Re: First layup
« Reply #8 on: May 06, 2014, 09:43:05 AM »
Yes I can do custom but its pricey.
