  • July 17, 2025, 09:11:06 PM
Author Topic: Carb Cleaner  (Read 2232 times)
Offline Bootlegger
Carb Cleaner
« on: July 12, 2017, 01:17:37 PM »
  Has any one tried this to clean up an engine, and how did it work?  Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Fred Quedenfeld jr
Re: Carb Cleaner
« Reply #1 on: July 12, 2017, 02:31:59 PM »
there used to be stuff called 2 plus 2 it worked great but it is no longer avaliable
Fred Q
Online Motorman
Re: Carb Cleaner
« Reply #2 on: July 12, 2017, 02:42:54 PM »
Any strong alkaline would work ok.  I use castrol super clean and scrub brush but if it's really burnt on you have to bead blast. I use to electro clean parts with red devil drain cleaner mixed into a caustic soda. I'm from Jersey though.
Offline Bootlegger
Re: Carb Cleaner
« Reply #3 on: July 12, 2017, 03:38:51 PM »
  How did it do cleaning the inside? I have an engine that the wrist pin will not move and I want to try to get it cleaned so that I don't do any damage to it.
  Again thanks
Gil Causey
AMA# 6964
Re: Carb Cleaner
« Reply #4 on: July 12, 2017, 04:03:42 PM »
I use  Berryman's  Carb Clean   It comes in a gallon pail  with it own  dip tray, leave in overnight, the burned on crud  washers right off.
https://www.berrymanproducts.com/products/eco-friendly-products/berryman-chem-dip-carburetor-and-parts-cleaner/
Online Motorman
Re: Carb Cleaner
« Reply #5 on: July 12, 2017, 04:38:17 PM »
Have you tried heat? Put it in an oven @ 250 for 20 minutes. You can make a puller. Round off the end of 1/16" music wire then bend a small hook in it so you can get behind the rod near the top. Hold the other end with vise grips. The heat will soften the goop so pull while it's still hot. If you make the hook just right you can pry against the counter weight.
Re: Carb Cleaner
« Reply #6 on: July 13, 2017, 12:28:09 AM »
   Remove any plastic parts and the backplate, and put it in the oven at 250-300. It will loosen up. Failing that, crock-pot. I would avoid any chemicals aside from ethylene glycol.
Offline Bootlegger
Re: Carb Cleaner
« Reply #7 on: July 13, 2017, 10:46:33 AM »
  Thanks a lot guys, I really do appreciate all the suggestions/help..  Again thanks.//
Gil Causey
AMA# 6964
Offline Phil Spillman
Re: Carb Cleaner
« Reply #8 on: July 13, 2017, 07:21:17 PM »
Insofar as pulling a stuck rod goes try using a small or just large enough to fit allen wrench! These work well and your not pulling against a piece of bent piano wire which might straighten and really scratch something!
Phil Spillman
Phil Spillman
Offline Ed Barry
Re: Carb Cleaner
« Reply #9 on: July 22, 2017, 08:06:43 AM »
Berkebile 2 + 2 is still available from Amazon at $4.99 a can.
ED Barry
