  • July 29, 2025, 09:56:43 AM
Author Topic: Remote Glow Plug Connection  (Read 3594 times)
Online Dick Pacini
« on: February 22, 2012, 08:18:40 AM »
I have ordered a couple of Hangar 9 remote glow plug adapters and plan on using one in every plane I build.  The issue of safety by keeping my hands away from the prop as much as possible. is very important.  My glow plug igniter is a snug fit on the plug and takes a bit of effort to remove once the engine is started and I have never been comfortable with that.  The remote unit will be a vast improvement.
AMA 62221
Offline John Fitzgerald
  • No longer an AMA Member
Re: Remote Glow Plug Connection
« Reply #1 on: February 22, 2012, 09:59:39 AM »
Mine always falls off as soon as the engine fires on side mounted engines.  Sometimes the engine dies because of that.  The locking mechanism wears out fast.
Online Paul Taylor
« Reply #2 on: February 22, 2012, 01:49:54 PM »
I heard that they were used a lot back in the day.  Any truth to that?
Offline Rafael Gonzalez
« Reply #3 on: February 22, 2012, 04:37:30 PM »
I have used the same thing since I remember the 9 Lives Cat 1.5V ( Eveready telephone battery); modified Alligator clips or the clothes pin style clip by hanger 9. I have used the remote on my cowled R/C 4cy engines though... Good safety tip!  y1
 H^^
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #4 on: February 23, 2012, 06:49:21 AM »
I have used the H9 remote glow starter on my last two planes
with inverted engines. This is a quality product and the safety
aspect cannot be overstated. This item comes with lengthy
wires, so I cut them, shorten them and resolder. Total weight
is .5 oz. A ridiculously small weight penalty to pay for the added
safety of this system.
Later, Steve
Offline Clayton Berry
  • Grey haired kid to be wary of
« Reply #5 on: February 27, 2012, 11:04:39 AM »
Hey, I only have one arm that works.  My mother-in-law asks what the hell I'm doing.  Wife says he's gonna fly a little before dinner.  But, he's flipping an engine with the only hand that works!  A Saito 56.  Is he nuts?
I got a chicken stick for Christmas that year.  Works great for reeling in the lines.  Mother-in-laws.  Can't live with them.  Just ask the father-in-law.
And the difference between an in-law and an outlaw?  The outlaw is at least wanted by someone.
Clayton - forever busy committing random acts of coolness
Online Paul Taylor
« Reply #6 on: February 28, 2012, 12:27:02 PM »
Later, Steve
Steve,
Can you post a picture of your setup?
Offline SteveMoon
« Reply #7 on: February 28, 2012, 12:39:58 PM »
I'm out of the country right now until 3/8 and just have my IPad with me.
Once I return home I'll post some pics. I've got some on the composer
at home.
Offline George
  • Love people, Use things.
« Reply #8 on: February 28, 2012, 01:20:24 PM »
The most remote glow plug setup is the one sitting at home 'cause you're currently flying your diesel.  S?P
The old 9-Lives battery (I used two in parallel) and alligator clips worked...you surely were not going to take off with them connected. The alligator clips were a little tricky with some half-A engines though. Many just pulled them off after the engine was running...others carefully disconnected the clips.
My favorite is still the clip-on KWIK-KLIP type previously made by various companies.
Actually, remote setups make more and more sense as engines get larger and more powerful, and props get stronger and sharper.
George
George Bain
AMA 23454
Online Paul Taylor
« Reply #9 on: February 28, 2012, 01:37:05 PM »
at home.
Cool... that Steve.
Out of the country? Are you in New York City or maybe San Francisco? LL~ LL~ LL~
Dat dar is funny I don't care who ya are..... Getter Dunn!!!!
« Reply #10 on: February 28, 2012, 02:34:20 PM »
I am seriously considering using one for the first time.  An inverted Saito .72!
BIG Bear
RNMM/AMM
Offline Ron Hess Sr
« Reply #11 on: February 28, 2012, 04:53:52 PM »
Here is a pic I found somewhere ;D
Online Paul Taylor
« Reply #12 on: February 28, 2012, 05:00:23 PM »
That looks very cool Ron, and the remote glow plug connector looks cool too.
Does it not require a two wire hook up? + & -
Online Dick Pacini
« Reply #13 on: February 28, 2012, 05:27:34 PM »
Where's the ground line?
AMA 62221
Online Dick Pacini
« Reply #14 on: February 28, 2012, 05:38:21 PM »
The unit I bought has a clip and wire that goes to the glow plug, a separate ground wire that goes to the engine mounting lug and a socket that goes through the fuselage wall that accepts a male pin on a lead that is connected to the glow igniter.
http://www.hangar-9.com/ProdInfo/HAN/250/HAN3025-250.jpg
AMA 62221
« Reply #15 on: February 28, 2012, 05:49:49 PM »
HI Ron,
Which Mustang is that and what's the engine set up?
Thanks!
Offline Ron Hess Sr
« Reply #16 on: February 29, 2012, 02:05:14 PM »
The plane is a Seafire MK47  with a PA 75 and belongs to Yves Fernadez, and I think the remote glow lead set is for a Ofna gas car and if you go to tower hobbie and look up part #LXABJD you should find it for $14.39.(remote glow lead set) here is a pic of it, resolder a difference clip on it and your good to go,I'm sure the clip is a body clip from a 1/10 r/c car also,and I got the pic of the plane from pampa pic gallery.  very nice plane.  y1
« Last Edit: March 03, 2012, 08:10:09 AM by Ron Hess Sr »
Offline SteveMoon
« Reply #17 on: March 09, 2012, 09:02:44 AM »
I finally made it home after my 8 day tour of Asia.
Here are a couple of pics of my setup using the Hangar 9
remote glow plug connector. A quality product that
I would recommend. The larger wire at the top of the
first photo is the adapter for the nicad glow starter.
Plugs into the nicad and then into the socket in the
side of the fuse.
