  • July 13, 2025, 11:29:33 AM
Author Topic: CAD Drawing for Infinity Bellcrank  (Read 3077 times)
« on: September 13, 2015, 07:05:40 PM »
Here is the original drawing for the Infinity bellcrank. Note that it specifies the materials clearly, including cross-grain balsa and a spacer where the ball link connects, and .025 6061T6 aluminum sheet. The only thing I do differently, and only for convenience, is make it 1/8" instead of 3/32 between the faces, and then use  1/8x1/4 circuit board standoffs for the spools instead of 3/32x3/16. I have tested this to destruction and it greatly exceeds the strength and durability of 1/4" phenolic or delrin.
   I am sorry Chris' failed but it appears to not be constructed according to the drawing, wherever it came from.
Offline bill bischoff
Re: CAD Drawing for Infinity Bellcrank
« Reply #1 on: September 13, 2015, 07:18:31 PM »
I understand "end grain" balsa as mentioned in the other thread, but what is "cross-grain" balsa. To me it would mean two or more plies of balsa glued together with the grain staggered 90 degrees.
« Reply #2 on: September 13, 2015, 07:27:20 PM »
  End grain= cross grain.  The grain goes across from top to bottom, like Mallite.
« Reply #3 on: September 13, 2015, 08:07:12 PM »
My rule of thumb is that if someone asks, then I need to make the directions more clear -- I believe that end-grain is the more common term, but a double-headed arrow on the drawing with a comment "run the grain this way" would remove as much ambiguity as can be humanly done.
« Reply #4 on: September 13, 2015, 08:20:26 PM »
   This was never intended to be distributed and these are not instructions on how to build one. The original description is perfectly clear, as were the directions I provided to Tom Morris.
Offline Allan Perret
  • Proverbs
« Reply #5 on: September 14, 2015, 08:31:41 AM »
Hey Brett, curious why you chose the 6061 aluminum for this,  isn't 2024 stronger ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: September 14, 2015, 09:30:17 AM »
  Because 6061 was more than adequate. I cannot emphasize how much effort it took to break my test articles, it would have rendered a standard flat bell crank  into a U-crank at half the load. There's some other issue here.
  • Proverbs
« Reply #7 on: September 14, 2015, 10:39:10 AM »
One other thing I don't understand.  What is reason for the pushrod attachment hole displaced 1/16" aft of center ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #8 on: September 14, 2015, 12:25:15 PM »
  To correct the geometry for the leadout sweep and pushrod angles. It's not the same for every airplane.
Offline Perry Rose
« Reply #9 on: September 15, 2015, 04:21:00 AM »
Did it hurt when you broke your testarticles?
Online Carl Cisneros
« Reply #10 on: September 15, 2015, 07:00:37 AM »
Perry
OMG    ::)
good one tho,,,,,,,,,,,
Carl R Cisneros, Dist IV
Control Line RB
« Reply #11 on: September 15, 2015, 12:06:25 PM »
Am I correct in thinking that this BC is intended to be installed "normal" and not "reversed"? I.e., "up" leadout will be the rear one.  ???
Vertical grain would be the only way to go with this design. It would allow much better epoxy penetration, pretty close to 100%. The balsa would not fail in this configuration, tho the epoxy/aluminum bond most certainly could, if the aluminum wasn't properly prepped. Anybody with a 10" table saw (and a decent blade) could slice off 3/32" slabs of hard balsa that would be perfect for the core.   y1  Steve
« Reply #12 on: September 15, 2015, 01:26:31 PM »
     Yes. You could easily design it to go the other way around, and it has some advantages in terms of pushrod clearance over some of the other leadout termination methods, but I don't think there's any good reason to put it in backwards, and I haven't seen many reverse systems used recently.
