  • June 28, 2025, 07:34:13 PM
Author Topic: Byron barkers Envoy  (Read 2501 times)
Offline Andrew Saunders
  • 2013 Nats
Byron barkers Envoy
« on: May 12, 2014, 06:16:19 PM »
This past February i had gotten Byron Barker's Envoy. The fuselage had some bare wood spots, the wing needed patching, and the engine on the plane is a super Tigre 60 that byron reworked himself and was  frozen from dried up castor. I had repainted the fuselage so its at least sealed, and kept the original wing coverin. The engine i worked on and freed it up. It still has allot of compression and did a test run on the engine yesterday. Runs great. Ill post a before and after pic.
« Last Edit: May 12, 2014, 07:36:20 PM by Andrew Saunders »
  • 2013 Nats
Re: Byron barkers Envoy
« Reply #1 on: May 12, 2014, 06:20:40 PM »
Heres the before.
  • 2013 Nats
« Reply #2 on: May 12, 2014, 06:30:00 PM »
Heres the after
Online afml
« Reply #3 on: May 12, 2014, 07:28:25 PM »
WELL DONE Andrew!!! #^
I'm sure Byron is look'n down with 'all smiles'!
Good luck & "Tight Lines!" H^^
Wes
Wes Eakin
  • 2013 Nats
« Reply #4 on: May 12, 2014, 07:37:56 PM »
Thank you  Wes!!!
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: May 12, 2014, 11:05:35 PM »
Byron and Allen both, nice job! 8)
Pete Cunha
Sacramento CA.
AMA 57499
  • 2013 Nats
« Reply #6 on: May 13, 2014, 04:37:00 PM »
Two more after pics
  • 2013 Nats
« Reply #7 on: May 13, 2014, 04:37:25 PM »
Thank you Pete!!!
  • 2013 Nats
Online James Mills
« Reply #9 on: May 14, 2014, 10:17:24 PM »
Looks good Drew, look forward to seeing it in the air.  You did Byron and Allen proud. y1
James
AMA 491167
« Reply #10 on: May 15, 2014, 02:23:33 AM »
   I really think that may be one of Allen's models, the more I think about it, from way back in his ST.60 days. Probably gave/old/traded it to Byron maybe? With Allen's finishing methods, old AMA numbers can be changed out pretty easy, depending on how he put them on. Unless you know the specific history of the airplane, it may be a double dip in significant previous owners.
   If you haven't flown it yet, get yourself some Vess 13-6 props for that Tigre .60. It's the best current production wood prop I have found for them yet.
  Have fun and fly well with it,
« Reply #11 on: May 15, 2014, 04:24:56 AM »
Andrew you have done Byron very proud. You've honored all of us with that effort. #^
  • 2013 Nats
« Reply #12 on: May 15, 2014, 03:42:56 PM »
Dan you are right. I talked to Wes Aekins and This Envoy was originally owned by Allen Brickhaus. Allen did a great Job desgning the plane also. Byron flew it for awhile till he wasnt able to fly . Im not sure if im gonna fly the plane or not. Im not too sure on the shape and reliability of the leadouts. Im gonna do a pull test on it first and make my decision on wether to fly it or not.
