  • July 27, 2025, 02:04:54 PM
Author Topic: Blank  (Read 1036 times)
Offline Rusty
Blank
« on: May 29, 2016, 02:37:07 PM »
Blank
« Last Edit: March 11, 2022, 07:11:55 PM by Air Master »
Offline pat king
    • PDK LLC
Re: What is the threads enya clamp on muffler?
« Reply #1 on: May 29, 2016, 02:49:24 PM »
3 X .6 JIS  They are not the ISO standard M3 X .5 screws.
Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #2 on: May 29, 2016, 09:00:32 PM »
M3 X .6 screws are almost impossible to find here in the USA, I think they are getting scarce in Japan. You can re-tap the clamp to M3.5 X .6 . Those are ISO standard and available here, or the easiest is to re-tap 6-32 and use readily available 6-32 screws. #6 screws and M3.5 screws are the virtually the same OD (.0002" difference).
Pat
Pat King
Monee, IL
AMA 168941
Offline Steve Thomas
« Reply #3 on: May 29, 2016, 10:24:40 PM »
Have you tried just emailing Enya?
Offline Dallas Hanna
« Reply #4 on: May 30, 2016, 03:10:05 AM »
Short length (12mm) still available from Micro Fasteners.
https://www.microfasteners.com/scm3012p6-m3-x-0.6-x-12mm-socket-head-cap-screws-metric-alloy.html
If you need any longer you could sacrifice a 50mm long screw by cutting off the 0.5 pitch thread length and then thread the remaining shank with 0.6 pitch
HH
