  • July 03, 2025, 01:12:23 AM
Author Topic: Great plans site  (Read 2839 times)
Great plans site
« on: November 24, 2017, 12:23:40 PM »
Was doing a search for plans for the Sterling Yak 9 profile (which I didn't find) and came across this site that has hundreds of PDF plans. Great place to brows for old ships https://www.rcgroups.com/forums/showthread.php?1288656-Control-Line-Plans
Enjoy,    DennisT
« Last Edit: November 24, 2017, 12:48:01 PM by Dennis Toth »
Offline PerttiMe
Re: Great plans site
« Reply #1 on: November 26, 2017, 09:29:43 AM »
Lots of plans from various rcgroups threads can also be found on a number of free plans sites. My favorite is https://outerzone.co.uk/ .
Offline George Albo
« Reply #2 on: November 26, 2017, 10:21:41 AM »
Enjoy,    DennisT
Please post when you find the Sterling Yak 9 plan.
Offline Serge_Krauss
« Reply #3 on: November 26, 2017, 08:54:35 PM »
George, I don't think you'll find a Sterling Yak-9 plan. The kit came with a small-scale 2-view on the instruction sheet. I took my plans to a copier several years ago and just had it copied at a magnification that gave it the correct span. If you want to fly OTS with something built from such plans, that should be legal, since it was "published." The only scans I have now were scanned at a low resolution to fit the other Forum, but I'll the jpeg version below, if it would be helpful. I can find my kit plans and scan at higher file size, if that would be useful. I also scanned some kit parts and the rib openings left from the die-cut wood, but these would not necessarily come out at the right size. However, if you look up the span (it's not on the box, but was in ads of the time - 38" or 40", I think), you can scale everything. The problem of magnification is that it also magnifies line widths and irregularities. BUT, you can build reasonably from such magnified images.
« Reply #4 on: November 26, 2017, 08:58:33 PM »
It was fun to look through the plans on that site and to see a couple Roy Clough, Jr. designs there. They weren't his most interesting, but they were, as always, imaginative.
SK
Offline John Cralley
« Reply #5 on: November 26, 2017, 09:32:03 PM »
Re: Sterling Yak 9 plans. I believe that Pat Johnston has drawn up a set of plans (probably using parts from a kit). He has it listed as plan #144. patsplans@yahoo.com
John Cralley
AMA 52183
Central Illinois
Offline Gordon Van Tighem
« Reply #6 on: November 26, 2017, 11:34:07 PM »
Gord VT
MAAC 3738L, Life Member
AMA C3738L
Offline Tony Drago
« Reply #7 on: November 27, 2017, 12:54:15 AM »
Also Barry Baxter
« Reply #8 on: November 28, 2017, 10:11:19 AM »
I'd forgotten that Brodak was producing the Yak, and their custom is to provide
 plans. I don't know for sure about authenticity, since there has been some discussion of wing sections in other models, but my guess is that these should make for a well-flying model. 'looks as though your problem is solved!
Offline George Albo
« Reply #9 on: January 29, 2018, 02:21:32 PM »
Hey Serge, a little late in my response, but this will do fine.  I have no problem with the line thickness. I just needed the outline and location of elevator relative to the wing, etc-  Thanks George
Offline Phil Krankowski
« Reply #10 on: January 29, 2018, 07:30:36 PM »
Free Login required for these two.
Hip pocket aeronautics
http://www.hippocketaeronautics.com
Aerofred
https://aerofred.com
There is a cl yak 9 on aerofred, but it is not Sterling's.
Phil
