  • July 15, 2025, 11:29:44 PM
Author Topic: Building Benchtop Height  (Read 2047 times)
Offline Dick Pacini
« on: September 13, 2011, 01:50:12 PM »
I am thinking of raising my new bench by about 4 inches to facilitate building without having to bend my back too much.  Presently, it is 33.25" high.  I think a higher working surface will be easier on the back.  Any comments?
AMA 62221
Re: Building Benchtop Height
« Reply #1 on: September 13, 2011, 02:09:09 PM »
Tall-enough benches are very nice.  If you're tall, you're probably used to working on too-short benches.  If you're short, it's the other way around.  They really need to be made for you.
Go for it.
larry borden
« Reply #2 on: September 13, 2011, 02:36:06 PM »
I'm 6'2" and my benches are tall enough for me to work standing up or sitting on a bar stool.
Offline Douglas Ames
« Reply #3 on: September 13, 2011, 02:57:31 PM »
Watchmakers love tall benches for that very reason.
AMA 656546
Offline Steven Kientz
« Reply #4 on: September 13, 2011, 03:19:25 PM »
  I'm 6'5" and my bench is about elbow height. Works great.
Steve Kientz
AMA 855912
« Reply #5 on: September 13, 2011, 03:36:30 PM »
Mine is right at the top of my hipbone.
Offline Neville Legg
« Reply #6 on: September 13, 2011, 05:10:27 PM »
Is it connected to your..... thigh bone? ;D
Cheers
(not) Descartes
Offline Joseph Lijoi
« Reply #7 on: September 13, 2011, 05:51:45 PM »
Ergonomic load height for an operator on industrial equipment, like a guy putting parts into a machine that will automatically assemble the parts is 38"-42".  This is for someone who is standing.  Your hands will be a couple of inches above your waist.  The easiest on your back would be a bench that you could sit at for most assembly, and another one that was at 38"-42" inches.  Sounds like the easiest solution is a bench at 38"-42" and a height adjustable task or drafting chair on wheels, so you could sit or stand.  The drafting chairs have a ton of height adjustment.  Good luck.
« Reply #8 on: September 13, 2011, 06:54:03 PM »
I guess the only answer is to build what you are comfortable with, assuming a four hour build session. If no problems at that time, then the perfect height is there.  More often than not I go for about that time as time flys when building.  Then I really have to take a break.  LL~ LL~
Don't you mean 8 bells?
AMA 656546
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #9 on: September 13, 2011, 07:37:17 PM »
My workbench is 37" tall and has rails on exposed edges so stuff doesn't fall off. When I recieved the workbench 2nd hand it was too short and had the same problem, now I can stand and don't have to bend over. Best move I ever made raising it to 37"
Fred C.
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Larry Fruits
« Reply #10 on: September 14, 2011, 12:06:22 AM »
 Dick:
 My workbench is 37 inches tall. I am 5'9" and that puts the bench top right at my elbows. I can work at it comfortably standing or on an adjustable stool. 33" would be too low for me and cause back problems. I agree with other comments though, you have to find a height that is "comfortable" for you. As you can see, we all have different heights for our tables, which are probably comfortable for each of us. Don't hesitate to raise yours up. I bet you will be glad you did.
  Larry
Mike Griffin
« Reply #11 on: September 14, 2011, 10:05:17 AM »
Dick as you know, I am cursed with bad knees and a bad back but as a cottage kit manufacturer I am on my feet a lot.  My back hurts if I am standing or sitting and I have found it almost impossible to build kits lying down.   y1
So what I did was go to Sam's  Wholesale and bought me a butcher block workbench with steel legs which is 38" high.  Then I went to Sears and bought a high swivel stool with a back on it.  I prefer to build standing up because there are so many steps that require it but I have found when my knees and  back REALLY start to hurt, I can either lean against the stool or sit in it and be high enough above the work that I can see what I am doing and still build.
This works for me, I do not know how it would work for anyone else.  Hope this helped.
Mike Griffin
« Reply #12 on: September 14, 2011, 10:06:40 AM »
By the way Dick, if you raise your bench by 4 inches that would bring it to about the same height as mine and some of the other guys who posted on this.  I am 5'11" and it works for me.
« Reply #13 on: September 14, 2011, 05:08:37 PM »
I'm 6'1" and my build island is at 38.5, and since I have a neck injury from long ago I wish it was 2 inches higher.
If I work at my electronic bench at 36" I end up going to the bone cracker the next day, so I have padded lifts to lay the work on that raise it another 4'.  That works well and, as others have pointed out, a bar stool works fine.  I found two that were nicely padded at a garage sale for 5 bucks for both!  (That lets the cat set up there with me since I can only set on one at a time.) n~
Offline John Eyer
« Reply #14 on: September 14, 2011, 08:14:32 PM »
d
« Last Edit: November 22, 2012, 11:22:11 AM by John Eyer »
