  • July 18, 2025, 06:50:54 PM
Author Topic: Brodak Shark 402  (Read 2012 times)
Offline Billy Fields
Brodak Shark 402
« on: October 29, 2018, 03:12:19 PM »
Has anyone built this model? or have seen one fly. Thanks
Rick_Huff
Re: Brodak Shark 402
« Reply #1 on: October 29, 2018, 04:08:20 PM »
Billy,
I've built two of the Shark 402's and they are great fliers for a small plane.
Rick
« Reply #2 on: October 29, 2018, 04:20:07 PM »
Billy,
Rick
what motor combos have you used Rick.
Offline James Holford
« Reply #3 on: October 29, 2018, 06:11:45 PM »
I started one. Built the wing except for wingtips. Then noticed the leadout wires were too short.... check that before you put center sheeting.
I was gona use a .25LA
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Gerald Arana
« Reply #4 on: October 29, 2018, 06:48:11 PM »
I built one with an OS FP 25. Flew great!
Only thing (for me) was that the ribs are extremely delicate. I think I broke every one before I finally got it covered. I used the SLC over polyspan and it wasn't that easy, but the results were great!
Good luck, Jerry
Online C.T. Schaefer
« Reply #5 on: October 30, 2018, 05:03:25 AM »
Like mine!  LA .25 stock muffler on .012x58 lines. Brodak .25 another good choice.  TS
Offline Perry Rose
« Reply #6 on: October 30, 2018, 05:28:55 AM »
Contact Pat Johnston he has two larger Sharks, a 560 and 610 sq in. Perfect for the .40 and .46 engines.
Rick_Huff
« Reply #7 on: October 30, 2018, 10:59:24 AM »
Billy,
Both of them are electric, using Cobra 2814/16 motors and 4s 1800mAh batteries (for the beginner's pattern).  I think 2200mAh batteries would be enough for the advanced pattern.
Rick
« Reply #8 on: October 30, 2018, 06:34:21 PM »
Thanks for the input guys wonderful help. Still undecided. Thanks Billy
« Reply #9 on: October 31, 2018, 05:59:17 PM »
We know Pat Johnston pretty well here in the NW. It'll fly as well as you can ask for. If you build it straight and adjust it correctly, you'll be a happy camper. The .25LA is perfect. Avoid the Fox .35 Stunt vibrations if you can!  H^^ Steve
