  • July 21, 2025, 01:28:17 PM
Author Topic: first LOOP in 35 years!!  (Read 975 times)
Offline DanielGelinas
« on: April 30, 2011, 06:29:21 PM »
OK, I know I'm annoying to all you guys but really...I'm excited!!
First loop with a brodak trainer to boot!!
My son was pretty impressed.
I dit a bad move in the end though and bke the propeller and shaft right off the crankshaft.  >:( >:(
Geez, I used to run these cox engines in the ground all the time when I was young and they NEVER broke. >:(
Anyone know whew I can get cox parts?
thanks,
-Danny  H^^
Re: first LOOP in 35 years!!
« Reply #1 on: April 30, 2011, 07:05:44 PM »
All the Cox 1/2a engines I know about use a 5-40 screw. If that's what broke, it's an easy fix if you can get the stub out. If the crank itself broke, then there's a Cox supplier in BC, Canada that has most the World's supply of NOS Cox parts. Look in the "Vendor's Corner" for "Cox International", or start checking around at model airplane swap meets. You might also post a "wanted" in the Classifieds or 1/2A forum.  H^^ Steve
« Reply #2 on: May 01, 2011, 04:32:48 AM »
You broke your Cox ?  ~^
« Reply #3 on: May 01, 2011, 06:44:43 AM »
I may have several older cox .049s let me see if I can find one that runs well, and I'll send it to ya! H^^
« Reply #4 on: May 01, 2011, 07:39:36 AM »
Thanks for the relies guys!
I have posted pictures in the engine section.
-Danny
« Reply #5 on: May 01, 2011, 11:45:19 AM »
Found one that will run, or you can use it for parts. PM me if ya want it...no charge. H^^
Offline Garf
    • Hangar Flying
« Reply #6 on: May 01, 2011, 01:01:14 PM »
I have a drawer full of lower ends for the Baby Bee type engines. Let me know if you need one.
