  • July 11, 2025, 08:06:06 PM
Author Topic: Small Washers for Cockpit Details  (Read 1784 times)
Offline JHildreth
« on: September 04, 2017, 06:30:11 PM »
      I have a DVD from Windy Urtnowski on cockpit detailing.  Windy describes making toggle switches using a very small washer and a flattened pin.  I would like to make some of these details for my current project, but I cannot find washers as small as the ones Windy uses.  The required washers are somewhat smaller than 2-56 washers.  Does anyone know where I might find the smaller washers?
Joe
Offline Phil Krankowski
Re: Small Washers for Cockpit Details
« Reply #1 on: September 04, 2017, 06:39:41 PM »
Try here?  It has been a while but I ordered stuff from here before.
https://www.microfasteners.com/
They have 00 brass washers, possibly other stuff  I didn't check all the categories.
Phil
« Reply #2 on: September 04, 2017, 06:46:25 PM »
Joe,
Some HS carry HO scale train nuts n bolts. That stuff can get really small. Small plastic tubes from HS also, but you would have to cut the ends off to make washers.
Good luck
CB
Offline JHildreth
« Reply #3 on: September 04, 2017, 07:08:24 PM »
Phil,
     I visited MicroFasteners' web site.  It appears that #00's are what I am looking for.  Thanks for the lead.
Avaiojet,
     The suggestion to visit the local model train shop is a good one.  I will do that first.  Thanks.
Thanks again to you both.
Joe
« Reply #4 on: September 05, 2017, 09:37:30 AM »
Joe,
One more thing, not washers but, On line you can find many photos and art of instrument panels. I actually did just that and printed the panel on gloss photo paper.
Light and looks great up close and from a distance.
Good luck.
CB
« Reply #5 on: September 06, 2017, 01:34:22 PM »
Try visiting your local beading store.  You may be surprised at what you find there.
I used silver beads instead of washers on my toggle switches.
Scott
« Reply #6 on: September 06, 2017, 02:12:06 PM »
Scott,
You forced me to put this up. I got those beads all over the place here. You can paint them.
CB
« Reply #7 on: September 07, 2017, 07:04:30 PM »
 Joe,
I mentioned printing sheets. I have a few sheets that I printed for my Jet Cockpit left over.
If you think you can make use, I send it along.
Here's a look.
CB
« Reply #8 on: September 08, 2017, 04:32:04 PM »
Joe,
 Probably the last photo I'll post for a time, we'll be loosing our electric power because of Irma. Couple of weeks probably. Not sure?
Just to keep the Thread going. Here's where I used that printed sheet. The cockpit build is at CFC Graphics.
CB
« Last Edit: September 08, 2017, 06:05:42 PM by Avaiojet »
« Reply #9 on: September 08, 2017, 06:07:19 PM »
Charles:
I like the canopy formers on that cockpit.  How did you do them?
« Reply #10 on: September 08, 2017, 06:35:55 PM »
But What About the Ejectoor Seat . S?P
Semi tragi comic Biography . A good read . The ' Test Pilot ' for Martin Baker Seats .
Not sure if this is the same book , different title . Havnt previously seen it .
Maybe its his previous exploits , and resume for the Martin Baker job .
« Reply #11 on: September 08, 2017, 06:43:33 PM »
This Mag has a 4 page Dave Rees artical on Lt Wt Styrene console & EJECTOR SEAT Cockpits , for his Talon & Gnat . ( ever any Rees GNAT Plans ?? )
Feb 75 .
« Reply #12 on: September 09, 2017, 12:00:49 PM »
Charles:
Scott, Here's a few photos, I don't have many from early on only recent photos when I decided to do the build.
Just balsa and 64th ply glued together with CA. Drew them out on paper first.
CB
« Reply #13 on: September 09, 2017, 02:04:47 PM »
They look good.  Thanks!
« Reply #14 on: September 09, 2017, 02:34:08 PM »
Scott,
The Jet Cockpit build is at CFC Graphics.
CB
