General control line discussion => Open Forum => Topic started by: JHildreth on September 04, 2017, 06:30:11 PM
I have a DVD from Windy Urtnowski on cockpit detailing. Windy describes making toggle switches using a very small washer and a flattened pin. I would like to make some of these details for my current project, but I cannot find washers as small as the ones Windy uses. The required washers are somewhat smaller than 2-56 washers. Does anyone know where I might find the smaller washers?
Joe
Try here? It has been a while but I ordered stuff from here before.
https://www.microfasteners.com/
They have 00 brass washers, possibly other stuff I didn't check all the categories.
Phil
Joe,
Some HS carry HO scale train nuts n bolts. That stuff can get really small. Small plastic tubes from HS also, but you would have to cut the ends off to make washers.
Good luck
CB
Phil,
I visited MicroFasteners' web site. It appears that #00's are what I am looking for. Thanks for the lead.
Avaiojet,
The suggestion to visit the local model train shop is a good one. I will do that first. Thanks.
Thanks again to you both.
Joe
Joe,
One more thing, not washers but, On line you can find many photos and art of instrument panels. I actually did just that and printed the panel on gloss photo paper.
Light and looks great up close and from a distance.
Good luck.
CB
Try visiting your local beading store. You may be surprised at what you find there.
I used silver beads instead of washers on my toggle switches.
Scott
Scott,
You forced me to put this up. I got those beads all over the place here. You can paint them.
CB
Joe,
I mentioned printing sheets. I have a few sheets that I printed for my Jet Cockpit left over.
If you think you can make use, I send it along.
Here's a look.
CB
Joe,
Probably the last photo I'll post for a time, we'll be loosing our electric power because of Irma. Couple of weeks probably. Not sure?
Just to keep the Thread going. Here's where I used that printed sheet. The cockpit build is at CFC Graphics.
CB
Charles:
I like the canopy formers on that cockpit. How did you do them?
But What About the Ejectoor Seat . S?P
(http://www.ejectorseats.co.uk/doddy1.jpg)
Semi tragi comic Biography . A good read . The ' Test Pilot ' for Martin Baker Seats .
(https://images-na.ssl-images-amazon.com/images/I/51W7UKgPEYL._SY344_BO1,204,203,200_.jpg)
Not sure if this is the same book , different title . Havnt previously seen it .
(https://images-na.ssl-images-amazon.com/images/I/41dq1bZrCmL._SX218_BO1,204,203,200_QL40_.jpg)
Maybe its his previous exploits , and resume for the Martin Baker job .
This Mag has a 4 page Dave Rees artical on Lt Wt Styrene console & EJECTOR SEAT Cockpits , for his Talon & Gnat . ( ever any Rees GNAT Plans ?? )
(https://i.ebayimg.com/images/g/XxgAAOxyfpJSVsqy/s-l500.jpg)
Feb 75 .
Charles:
Scott, Here's a few photos, I don't have many from early on only recent photos when I decided to do the build.
Just balsa and 64th ply glued together with CA. Drew them out on paper first.
CB
They look good. Thanks!
Scott,
The Jet Cockpit build is at CFC Graphics.
CB
