  • June 30, 2025, 06:31:55 PM
Author Topic: Brodak Crystal Clear  (Read 1472 times)
Offline Dan Berry
« on: June 30, 2021, 09:14:21 AM »
I might remember reading somewhere that Crystal Clear wasn't real fuel proof.
I'm needing to know if it's up to the job on a FF Gas plane. I only need it for the covering (tissue). I don't have enough of anything else for the current project and don't have time nor do I care to spend any money on the plane. I have plenty of the 9unopened) Crystal Clear.
I don't need super-galactic fuel proof but it needs not soften immediately.
Thanks for indulging me.
Offline Jim Svitko
Re: Brodak Crystal Clear
« Reply #1 on: June 30, 2021, 09:26:39 AM »
My experience with Brodak Crystal Clear has not been very good.  Although others did not have this problem, I noticed that the gloss disappeared when raw fuel touched it.  Wiping off the fuel also removed the gloss.  I have no idea if it was softened as well.  I did not try any other experiments with it after that.
I also had it turn an ugly brown in short order.  When the dope arrived, I opened both cans to see if it was truly crystal clear.  It was.  Several months later, when I went to use it, it had turned an ugly brown.  I disposed of it, not wanting to take any chances.
I have no idea if opening the cans then resealing allowed some contaminant to enter and cause the discoloration.  No other dope I have had did that so I wonder about the formulation of the Brodak Crystal Clear.
Offline Dave Harmon
« Reply #2 on: June 30, 2021, 08:20:55 PM »
Dan...The old 'Tuff' fuel proofer sold by Victor Stanzel was liquid vinyl.
If you could find the vinyl somewhere it would work well over dope.
Everyone used it a lot.
Offline gene poremba
« Reply #3 on: July 01, 2021, 01:19:00 PM »
 My experience with Brodak crystal clear is that when raw fuel gets on it, it dulls right away. Also, when i buy it and use it right away it is very clear. If the crystal clear sits in the shop a few months it is a yellow to rusty brown tint...gene
Offline Dan Berry
« Reply #4 on: July 02, 2021, 07:23:38 AM »
Thanks for the help.
« Reply #5 on: July 02, 2021, 08:18:18 AM »
Ya gotta love those non catalyst top coats which are 100% fuel proof.
Offline 944_Jim
« Reply #6 on: July 02, 2021, 10:44:10 AM »
I'm intrigued, Charles.
Can you briefly describe or name the NON-catalyst, 100% top coats?
My butyrate dope supply is running low/old.
Thanks in advance,
Jim in MS
