  • July 01, 2025, 06:11:49 AM
Author Topic: Brodak Ares in Primer  (Read 12669 times)
Offline Matt Colan
« on: February 13, 2009, 06:17:36 PM »
Hi everybody in stuntland!
Here is a couple of pics of my Brodak Ares in Primer.  This is about its 3rd coat of primer.  After sanding it off, comes color.  All Brodak colors, gray, sky blue, and black.
It was sprayed about 10 minutes before these pics were taken and I was too lazy to take it off the wall.
Enjoy!!!  H^^
Offline Leester
Re: Brodak Ares in Primer
« Reply #1 on: February 13, 2009, 06:20:59 PM »
Can't wait to see it with color on it. Be sure to keep us posted.
Leester
ama 830538
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: February 14, 2009, 06:11:32 AM »
When you say "in primer" what primer are you talking about.. DupliColor?
If it is DupliColor can you tell me what a coat weighs before sanding? Just wondering how it compairs with a ZS filler coat following Randy's instructions which is 0.9 ounces before completely dry or sanded...
Maybe I should add, this is on a 680 sq/in wing..
Offline Matt Colan
« Reply #3 on: February 14, 2009, 10:53:13 AM »
I'm not using dupliColor.  I'm using Auto Primer.  This stuff is heavy and most of it is sanded off anyway.
Edit:  Today I sprayed it with a coat of gray.  Also I started to lay out the trim scheme on the plans.
« Last Edit: February 14, 2009, 04:28:44 PM by Matt Colan »
« Reply #4 on: February 14, 2009, 05:19:19 PM »
All I can say is, you and some others on here do GREAT WORK! 8)
« Reply #5 on: February 14, 2009, 05:47:45 PM »
Nicely turned out model there, Matt.
Please keep posting pics so we can all see your progress.
Chris...
Offline Leester
« Reply #6 on: February 14, 2009, 06:21:00 PM »
Matt, DupliColor is auto primer from Auto Zone.
Leester
ama 830538
Offline Matt Colan
« Reply #7 on: February 14, 2009, 06:43:00 PM »
This is actually only my 3rd kit build and my first I-beamer.  My first plane was an ARF that I bought in 2005, and I still have it.  My next plane was a Brodak profile Fw-190.  Once again I still have it.  In May of 2007, I bought a Smoothie ARC that I put together.  The Ares I started to put together In the winter of 2008.  Flying season came and I got distracted flying.  I got my flying up to advanced.  Starting in about August I started put it together.  Slowly but surely I got up to this stage.
Next week, I will start my Oriental Plus that Bill Hummel gave me.  He also gave me the Ares kit.  Both planes I plan on bringing to the Nats this year along with my smoothie ARC to fly in OTS.
Thanks Bill  H^^
« Reply #8 on: February 18, 2009, 08:37:42 PM »
Matt,
Did you get any finishing done this past weekend?
Chris...
Offline Matt Colan
« Reply #9 on: February 19, 2009, 03:12:24 PM »
Yes.  I got a coat of grey on, filled the major cracks that showed up and sanded it down.  Then I sprayed the final coat of grey on.  Tomorrow I will start masking for the trim.  I will also post pics tomorrow.
Offline Claudio Chacon
« Reply #10 on: February 19, 2009, 03:27:08 PM »
Way cool Matt! I Beamers forever!
Looking forward to see your progress...
Keep us posted! #^
Offline Bob Reeves
« Reply #11 on: February 19, 2009, 03:27:46 PM »
Mind saying what you used for filler..
Offline Matt Colan
« Reply #12 on: February 19, 2009, 03:57:34 PM »
I used regular old Spackle, sanded it down and sprayed over it.  Spackle is water based and takes a long time to dry, but comes off like powder.  It is actually the same material that is on my ceiling at my house.
Offline Matt Colan
« Reply #13 on: February 21, 2009, 03:50:00 PM »
Here are a couple of pictures of the Ares.  Today I sprayed it in Brodak Sky Blue for trim.
Offline RC Storick
« Reply #14 on: February 23, 2009, 07:26:58 AM »
Matt take this from experience. Spackle will soften with dope (aside from being extremely heavy). So if you use this, spread CA over it in a thin coat to sear it and this will stop the softening. Good luck and keep building.
Offline Bob Reeves
« Reply #15 on: February 23, 2009, 09:18:15 AM »
Have not had any problems with the light weight pre mixed Spackle sold in the little plastic containers.. Sure allot lighter than auto body filler and so far , couple years seems completely compatible with dope.
However, if that blue tape is the stuff I'm thinking it is, it can cause problems with dope.. Look inside the roll and see if it doesn't say something about not using it with lacquer. Dope is a lacquer and the adhesive will attack it.. My experience, before reading the inside of the roll was it left a channel where the tape was, not a complete disaster but irritating.
Offline Matt Colan
« Reply #16 on: February 23, 2009, 01:38:17 PM »
Here is the Ares ready for clear.  On Saturday, I sprayed the Sky blue,  Sunday I sprayed the wings and fuselage black.  Today I mixed a custom gold to try to get my numbers to look like the Ares decal.  I think I got it pretty close for an amateur.  Right now the Ares weighs 40.8 ounces with everything on it so I think I'm going to reach my goal of 42 ounces for weight.
Enjoy!!!  H^^
Offline Bob Reeves
« Reply #17 on: February 23, 2009, 02:19:21 PM »
Looks great..
« Reply #18 on: February 23, 2009, 03:57:50 PM »
Young man you learn fast as well as listen.  That is one gorgeous airplane.  It ought to fly great at that weight.  DOC Holliday
Offline Matt Colan
« Reply #19 on: February 23, 2009, 04:20:07 PM »
Thanks John,  If you look in one of the above pictures, it shows I am spraying with an airbrush.  I prefer to spray with an airbrush, because it is light and I have been using that longer and am more comfortable spraying with it rather than a big spray gun.  I'm actually suprised how quickly the paint went on.
I can't wait to see it fly either.
« Reply #20 on: February 23, 2009, 05:21:24 PM »
Matt, congrats on one very fine looking model. I'm sure you're proud but I'm absolutely positive your gramps is bustingat the seams with pride in you. It should be a great flyer at that weight, we'll look forward to the flight reports/
Offline Matt Colan
« Reply #21 on: February 23, 2009, 07:53:23 PM »
Randy,  It will take a while to here flight reports since Vermont just had another snow storm and we don't start flying until late March to early April.
« Reply #22 on: February 23, 2009, 08:43:37 PM »
Same here in Michigan Matt, we still want fight reports!
Offline Matt Colan
« Reply #23 on: February 24, 2009, 05:39:39 AM »
I know.  Winter becomes depressing, for me at least after a while.  You can be sure there will be flight reports when it flies.  H^^
« Reply #24 on: February 24, 2009, 09:05:43 AM »
Matt, I too use an airbrush as I can control it a lot better.  DOC Holliday
« Reply #25 on: February 24, 2009, 10:17:17 PM »
Hi Matt,
Nice looking scheme. Well done, it's simple and neat.
Glad to see you're progressing so well on the Ares.
chris...
Online Dennis Adamisin
« Reply #26 on: February 26, 2009, 08:47:29 PM »
Matt:
I got two words for ya buddy: SHOW-OFF!!!   8) #^  H^^  CLP** BW@ HH%%
That is a wonderful trim scheme, true to the theme of the I-Beamers of that era.  You really nailed it.  I think it is going to be a winner for you, just as it was for Billy.
« Reply #27 on: February 26, 2009, 09:27:13 PM »
Mighty fine looking bird right there....I wish I had kept my airbrush...........watching you step by step putting that scheme together makes me really yearn for the good ole days when I was painting car bodies for RC and slots. Although I can't figure out how you get away with doing it in the house like that.....my woman nearly left me over the smell and overspray! Like the others.....I'll be waiting on your flight reports! H^^
Offline Matt Colan
« Reply #28 on: February 27, 2009, 05:48:40 AM »
John, I'm not sure if you can see it in the pictures but the window right above where I was spraying, my grandfather puts an exhaust fan in that he turned around.  When it running at full blast it sucks everything out, even the heat.  The smell is still there and I wonder if our noses have become immune to it.  My grandfather and I don't smell a thing and when my grandmother comes downstairs, she says, "Oh what's that smell? It stinks down here!"
Matt:
Dennis, I hope it is going to be a winner to.  I did notice though that there is a slight warp on the leading edge of the inboard wing.  I guess a flap adjustment during flight trim could cure that.  This plane is going to the Nats with me this year, but to fly in classic.  I'm going to fly my Oriental Plus that I started 2 days ago for Junior and advanced.  Both should fly great.  H^^
Offline stunt1
  • ACE
« Reply #29 on: February 27, 2009, 08:28:09 AM »
Hey Matt,
You did a "Great Job" on your new "Ares". Like Dennis Adamissin said, I think you nailed it. I think Grandpa and I are going to have to think about retiring if you keep going down the "Path" you're on. Grandpa has certainly been a "Good Teacher".
Looking forward to seeing the two of you at our "Big Jim" Stunt Contest in May. That's the week after "Labor Day" weekend.
Remaining yours in STUNT,
"Champione"
Bob "Champione" Lampione
New York Stunt Team
AMA-605
Offline Matt Colan
« Reply #30 on: February 27, 2009, 03:52:40 PM »
Hey Matt,
"Champione"
Hi Bob
I think the "Big Jim" contest in May is a little after Labor Day weekend. You sure you don't mean Memorial Day???
I don't know about Grandpa retiring, he says he is going to be the next John Dotavio (correct spelling) of the world.  Flying until he's 86 and years after.
I'm not sure we can make it to the Big Jim contest since we're going to the Nats and Lee and Wrentham to defend my title for the Mass Cup.  If we can, I'll be glad.  I would like to go.
Offline Matt Colan
« Reply #31 on: February 27, 2009, 04:04:50 PM »
HI Matt. That is too  neat. Pure classic. I think I'll steal the design for my new 59 Ares. #^ <= H^^
Can't it's copyrighted  LL~  LL~  LL~  LL~ .  Just kidding, go ahead and copy it.  H^^
Offline stunt1
  • ACE
« Reply #32 on: February 27, 2009, 04:53:26 PM »
Hi Matt,
You're right, Memorial Day Weekend, that is the week after.
See what happens when you get old, you lose all track of time. Don't worry though, your time will come just like the rest of us older folk.
Cheers,
Bob
New York Stunt Team
AMA-605
Offline Matt Colan
« Reply #33 on: February 27, 2009, 08:48:39 PM »
Hi Matt,
Cheers,
Bob
Grandpa has always been saying, every day is Sunday, while he has been retired.  Can't wait for flying season  H^^
Offline Matt Colan
« Reply #34 on: February 28, 2009, 04:19:16 PM »
Today I finished my Ares.  It weighs 43 ounces.  The cg is actually perfect as well as the vertical cg.  I started with 3/4 ounce of tip weight on the plane.  It is all done except for buffing which I will do next week.  The engine is an OS .35S and a Master Airscrew 10-6 wood prop to start with.  I can't wait to see it fly since it came out soooo well.
enjoy the pics  H^^
« Last Edit: February 28, 2009, 05:34:58 PM by Matt Colan »
« Reply #35 on: February 28, 2009, 06:37:08 PM »
Not only did the plane turn out great, but the pictures did too....I'm dazzled! n~  ;D
Offline Matt Colan
« Reply #36 on: February 28, 2009, 06:57:44 PM »
Thanks John, but actually I was in a rush to shoot the pictures and post them since I had to get back to my house for dinner.
Offline steve pagano
« Reply #37 on: February 28, 2009, 07:02:32 PM »
Hi Matt
      She looks real good. Be sure to let us know how she flies. You think you'll make it out to Flushing the season?
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Offline Matt Colan
« Reply #38 on: February 28, 2009, 07:06:46 PM »
Hi Matt
Hi Steve,  I'm not sure we can make it to Flushing.  I would like to.  Not sure we can make it because we are heading to the Nats, Lee and Wrentham.  I'll try to talk my grandparents into getting us to come to Flushing this year.
Offline Alan Hayes
« Reply #39 on: February 28, 2009, 07:13:50 PM »
Matt,
Great looking plane.....I still have one in the box........Looks like NC Tarheel colors.
Just kidding!
Alan
AMA 7064
"The measure of who we are is what we do with what we have" ~ Vince Lombardi
Offline Bryan Higgins
« Reply #40 on: March 02, 2009, 08:17:50 AM »
Matt
Great job building a perfect Ares. Like the trim work and
the light wieght of the stunter.   H^^ H^^
I gota build me one........ R%%%%         Bryan
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline Matt Colan
« Reply #41 on: March 02, 2009, 09:36:12 AM »
Matt
Thanks Bryan, but it isn't a perfect Ares, it still has its flaws in the wood, but I still really like how it came out.  If it was appearenced judged at the Nats, then it may be a 14 or 15 maybe a 16.
I can also tell my level of craftsmenship and finishing has gone up since my first kit, a profile Fw-190 to an ARC Smoothie and then the Ares.  My Oriental Plus that I started a week ago, I want it to look even better than the Ares since it is going to be at the Nats for advanced and Junior.
« Reply #42 on: March 02, 2009, 03:58:19 PM »
Very, VERY nice job Matt! As good as it gets...Congratulations!
Keep up your dedication to model airplanes (besides study, of course) and you'll be a happy person for the rest of your life...
Claudio.
Offline Matt Colan
« Reply #43 on: March 02, 2009, 04:30:13 PM »
Claudio.
Claudio
I have been looking at careers that would still allow me to fly these little planes.  I would like to become an airline pilot, so I get to live my passion and still allow me to fly the smaller versions of them.
« Reply #44 on: March 02, 2009, 06:24:27 PM »
Matt, get a hold of someone already in the airline business.  I too thought I would love to fly the big birds.  Besides not having the money for the education required I realized I had some physical disabilities also.  This day and age you need at least a college education as well as tons of flying experience.  DOC Holliday
Offline Matt Colan
« Reply #45 on: March 02, 2009, 07:57:04 PM »
The one thing I would need to do is get in shape, which may take a little bit.  There is a local airport that I think gives out flying lessons, but we don't have the money.  One college in Florida, prefers we have less flight experience before going to college.  I still have time since I'm only a Freshman in High school.
Offline Michael Floerchinger
    • Arcadia Acres
« Reply #46 on: March 03, 2009, 06:46:32 AM »
Hello Matt, great looking plane!
This is what our hobby is all about…………………
Good luck at the Nats!
« Reply #47 on: March 03, 2009, 07:48:37 AM »
Aim high, the sky is the limit....Good Luck! y1
Offline Matt Colan
« Reply #48 on: March 03, 2009, 05:25:41 PM »
This plane has had a lot of publicity, even before it flies.  Today, I got an email from Bob Hunt, asking if I could write about the Ares in the Appearance Point column.  I also sent Windy a few pictures of this plane, and knowing him, it is on his video.
I do hope it flies as good as it looks.
Offline Matt Colan
« Reply #49 on: March 03, 2009, 06:14:06 PM »
My next door neighbor flies for Jet Blue, so I could see how he became an airline pilot
Matt, get a scholarship, go to college, and then FLY NAVY.  Lot's of flying hours, real flying. Then apply to an airline. I know many former Naval Aviators that have done this. Fly and get paid. See the world, but to be honest it is a lot of water. H^^ D>K
I have thought about the NAVY, and the Air Force.  How did Dave Fitzgerald become an airline pilot? Or even Ted Fancher (are you out there Dave or Ted)?  Maybe they could chime in on this.
