In the past there has been a problem with Sig jugs leaking at the bottom. I had one of these which had set undetected for a long time, at least a year. The fuel level in the jug was down a little, and there was a vacuum in the jug. Clearly, it was no longer leaking. I am not sure what went on, but some how the leak got stopped, little fuel was lost, and it has given no problems.
That's one of the reasons I use Powermaster - it comes in cans and at least so far I haven't had a leaker. I also think keeping *light* off the fuel it important, if nothing else, the UV gets to plastic after a while and makes it brittle.
But otherwise, as long as air doesn't get in and out of the can, the storage conditions don't seem to matter much, either. My fuel sits in the back of the van, outside, for sometimes years, cycling up and down from the 40's to the 130s, and I have never had any issues.
I think a lot of problems are blamed on "bad fuel" when it's really something else. Fuel doesn't seem at all sensitive to storage conditions and if it came from the factory right, it doesn't seem to ever go over the hill unless you do something silly.
