  • July 23, 2025, 01:27:03 AM
Author Topic: Brodak 25 venturi size?  (Read 1963 times)
Offline frank williams
« on: August 02, 2014, 09:39:09 PM »
I got my Brodak 25 running the best it ever has by switching to all synthetic fuel.  The venturi that is in it is a 0.247 dia. with the .157 dia. spraybar.  Is this venturi bore too small?  Good draw, but power seemed down.
Frank
Offline Wayne J. Buran
Re: Brodak 25 venturi size?
« Reply #1 on: August 03, 2014, 05:05:33 AM »
The Brodak 25 I had seemed to be the happiest on a 10% blend. Props varied on application and I always ran a uniflow tank.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
« Reply #2 on: August 03, 2014, 07:29:27 AM »
Frank
  No one seems to believe me when I talk about oil drag, or about viscosity of the fuel affecting the flow stability.  All I can say is that I think you want as thin an oil as you can safely get away with, and as little flow restriction in the fuel supply you can possibly get.
Offline bob whitney
« Reply #3 on: August 03, 2014, 08:01:24 AM »
from what i can tell ,the B25 has almost no taper in the sleeve so piston drag with a lot of caster could be a problem ,along with a tight bushing up front .Blendzall makes a thin g Go Cart caster oil -ULTRA racing caster that works very good
rad racer
« Reply #4 on: August 03, 2014, 08:21:27 AM »
Thanks guys for the info.  I just mounted up a brand new B-25 on a Sky Ray that was collecting dust.   Took me a while to get all the crud off the plane.
« Reply #5 on: August 03, 2014, 05:23:30 PM »
Stock venturi? or something larger?
Frank
Offline Mike Greb
« Reply #6 on: August 03, 2014, 05:37:42 PM »
Might try boring it out about .01 inch and see if that makes any difference.   The one that I ran in OTS seemed rather weeny.  I am running that same engine in super slow rat with a .316 venturi.   I have run it thousands of laps in the super slow rat and it just keeps on going.  It was down on power at this years nats.   I devarnished the piston and liner, and now it is back to were it was.
Offline BillLee
« Reply #7 on: August 03, 2014, 05:39:36 PM »
Frank
Frank, for your SSR, you'll want to put about a .320" venture with a full spray bar.
You ARE talking about SSR, aren't you?  :)
Bill Lee
AMA 20018
Offline Balsa Butcher
  • High Desert Flier
« Reply #8 on: August 03, 2014, 06:58:11 PM »
Hi Frank, I have run the B-25 in both stunt/sport and SSR applications. Found it to be lacking in power with the stock venturi as you did. Put in a venturi from a B-40 which is about .305. This woke it up and is what I would do to start with. For SSR (as has been posted) even larger venturis can be used. I run a 9x4 prop for sport/stunt, an 8x6 for SSR. The other Lee (Jim) sells venturis of various sizes for this engine. I'm using one his on my B-40 (.283). As far as fuel goes, I'm happy with 10/22 GMA but may try full synthetic and see how it works.  8)
« Last Edit: August 03, 2014, 07:40:46 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
Offline Dane Martin
  • heli pilot BHOR
« Reply #9 on: August 03, 2014, 07:12:33 PM »
i haven't seen a lot, but the ones I've seen running very well were on a .255 venturi.
i agree with Brett on the fuel. you might look into the Brodak 10/11/11. but being a newer style engine, it might only "want" 18% oil.
I'd call John Brodak and ask him the oil content preference.
« Reply #10 on: August 03, 2014, 07:13:12 PM »
I don't have the numbers right now but, my B25 was much happier after I opened up the venturi.
« Reply #11 on: August 03, 2014, 07:54:52 PM »
Thanks All
I think I'll open it up a bit ....... its for a smalish (375in**2) stunt ship, not SSR, ... although you never know.
The fuel I ran was 15% w/23%low viscosity oil from VP.  Its one of their standard heli fuels, not bad for PA's either.
Frank
Offline Bootlegger
« Reply #12 on: August 07, 2014, 06:11:41 AM »
 Did running it on all synthetic have any adverse effects on the longevity of the engine? I am curious about only syn fuel in the newer engines, and am willing  sacrifice an engine to the cause, but I am still interested/concerned about the engine with only syn fuel also...
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #13 on: August 07, 2014, 08:49:54 AM »
Only experience I have is that you do not want to run the engine over lean too many times.   But, some of my engines run better with no castor.   Now the old Fox's are a different story.
