  • June 26, 2025, 04:41:23 AM
Author Topic: Size of the flaps on a SIG Akrobat?  (Read 1066 times)
« on: July 08, 2012, 02:21:32 PM »
Someone gave me a SIG Akrobat and the flaps seem real small.
1.5 inches at the root going down to .75 inch at the tip.
Anyone know if that is correct or should they be wider?
Offline Steve Schlesser
Re: Size of the flaps on a SIG Akrobat?
« Reply #1 on: July 08, 2012, 02:27:54 PM »
Paul,
  The plans show straight flaps, 1 1/2 in. at the root and 1 1/2 at the tip
« Reply #2 on: July 08, 2012, 03:04:25 PM »
Thanks Steve.
That seems a little small for the size of plane.
Is anyone flying one of these planes with this size flap?
« Reply #3 on: July 08, 2012, 03:24:33 PM »
Thanks Steve.
The flaps on my Twister are 2-1/4 at the root and 3/4 (or maybe 5/8) at the tip.  A straight 1-1/2 flap is the same area.
I suspect that when the original builder made it he tapered the flaps to look good, without considering the aerodynamic consequences.
Is the plane flyable?  Why not give it a whirl and see how it goes?
Offline Mike Mulligan
    • Mulligan Racing Development
« Reply #4 on: July 15, 2012, 03:04:23 PM »
Hi Paul,
I just had time to dig out my Akrobat kit and have a look. The plans show straight 1.5" wide flaps like Steve said, but the flaps supplied in the kit are actually 2" wide root to tip.
I suppose the constant-chord flaps were designed to look 'scale' as the real Zlin 526 has a straight trailing edge.
Hope thats of some use!
Mike Mulligan
AMA 789641
www.Mulliganracing.com Mike@Mulliganracing.com
