  • June 25, 2025, 08:45:13 AM
Author Topic: foam template filler ?  (Read 1293 times)
Offline jim gilmore
« on: November 17, 2010, 07:47:48 PM »
Ok, I'm cutting parts out for the 1/2A Shoestring  Maybe it should be a shoethread..
In any event I'm using that cheap foam board from the craft store and I want to fill in the gaps in the foam. Will plastic spakle work of does anybody have a better idea ?
Offline ray copeland
Re: foam template filler ?
« Reply #1 on: November 17, 2010, 08:29:51 PM »
Jim, nitro will eat that foam up so all exposed edges will need to be sealed! On my little platters i use titebond on the edges and gorilla glue to fill any large gaps.
Offline jim gilmore
« Reply #2 on: November 17, 2010, 08:41:40 PM »
these are just templates. no nitro
Offline David Shad
« Reply #3 on: November 18, 2010, 05:21:23 AM »
Problem with the spackle is it crumbles and falls out of the edges as time goes on (no sticky) so you might use some cheap wood glue...like titebond or even the not so cheap gorilla glue...maybe mix in some balsa dust like a micro balloon mix and fill the edges with that...it will make the templates last forever and the glue mix will not deteriorate over time.
Big Dave AMA 80235
Offline Michael Boucher
« Reply #4 on: November 18, 2010, 08:03:54 AM »
Not sure I fully understand this, but how about electric tape?  Just trying to help with an idea.
AMA 59633
Offline jim gilmore
« Reply #5 on: November 22, 2010, 12:25:40 PM »
Oh well. Using foam is not working.  So back to the drawing board for template material. Tryinng to use something I have good access to. Maybe plastic from milk bottles.
