  • July 23, 2025, 08:07:36 PM
Author Topic: Big Box  (Read 1151 times)
Offline Bootlegger
Big Box
« on: May 31, 2013, 06:20:17 AM »
 What spackling compound do you use from big box stores that sands easiely, low weight, dope sticks well as other paint/finishes do also?
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Larry Fernandez
Re: Big Box
« Reply #1 on: May 31, 2013, 09:55:27 AM »
None.
All spackling that I have tried over the years would shrink (I hate shrinkage). I also had problems with adhesion. Paint would bubble and even lift.
For small dings I have been using automotive spot putty. It like super thick lacquer primer so dope sticks to it very well and it sands easy.
Larry, Buttafucco Stunt Team
Re: Big Box
« Reply #2 on: May 31, 2013, 09:57:32 AM »
Go to the paint and finishing group, and do a search on "spackl" (spelling intentional -- it gets the most relevant hits), and another one on "putty".  You'll see lots and lots of useful discussion.
Re: Big Box
« Reply #3 on: May 31, 2013, 10:28:57 AM »
The April 2013 issue of CLW reports on a product called DAP "DryDex", a spackling putty reported not to shrink.
Re: Big Box
« Reply #4 on: May 31, 2013, 10:34:34 AM »
I use catalyzed glazing compound. It doesn't shrink at all and sands easily. Automotive product.
Offline Bootlegger
Re: Big Box
« Reply #5 on: May 31, 2013, 12:56:05 PM »
  As usual you fellow's came thru..  Thanks a lot     #^
Gil Causey
AMA# 6964
Offline Allan Perret
  • Proverbs
Re: Big Box
« Reply #6 on: May 31, 2013, 07:02:43 PM »
You can get a small tube of the automotive lacquer spot putty under the "Bondo" brand label for under $5 at Walmart.
The auto supply stores only have larger tubes which cost over $10..    Like others have said, it dries fast, sands real easy, and does not shrink.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Bootlegger
Re: Big Box
« Reply #7 on: June 01, 2013, 06:11:40 AM »
  Allan, I sent ya' a P.M. thanks
Gil Causey
AMA# 6964
