  • June 09, 2024, 03:50:57 PM
Author Topic: Bi-Slob stunts  (Read 5697 times)
Offline John Craig
Bi-Slob stunts
« on: April 14, 2014, 07:07:30 AM »
Bi-Slob
I have one. It flies very slow with good line tension.  For maximum giggles per once of fuel, what type of stunts should I be trying to do.  I have the super tight loops & hovering what else?
Re: Bi-Slob stunts
« Reply #1 on: April 14, 2014, 07:30:04 AM »
Bi-Slob
Balloon brake, Limbo under a stick, flight between two poles, bouncing it off the rudder inverted and last but not least, a mid level flight stop and go. Not to be confused with the tuch n go.
Re: Bi-Slob stunts
« Reply #2 on: April 14, 2014, 08:54:28 AM »
Just let your imagination go.   John Bender did one called a house.  It's  a verticle 8,  square loop bottom with triangle on top.
Offline dennis lipsett
Re: Bi-Slob stunts
« Reply #3 on: April 14, 2014, 09:26:54 AM »
The one that get them is the outside loop from 3 feet right into a hover, then repeat the maneuver. a small 4 leaf clover with the stem downward and recover into a hover is also a show stopper. be fearless after all your not in it and it isn't a whole lot of money and unless you have a flame out in the hover and implode the fuselage up to the wing it isn't catastrophic.
I liked mine but eventually gave it away promising myself to build a lighter one.
Re: Bi-Slob stunts
« Reply #4 on: April 15, 2014, 07:20:21 PM »
A search was called for to see what a Bi-Slob is......WOW)))))) I gotta get one of those. Looks fun. Control Line 3-D flying.
I do have an old .35 waiting for a plane.
Re: Bi-Slob stunts
« Reply #5 on: April 16, 2014, 08:20:59 AM »
They are a blast to play with.  When I built my first one Jim Lee said not to put too big of a fuel tank in it.   The concentration while hovering and doing loops low to the ground will wear an old man out.  The best show I seen with the Bi-Slob was when Jim Lee and Marvin Denny put on a show in Tulsa one year.   Sad to say no one had a movie camera with them that day.
Offline Tom Niebuhr
Re: Bi-Slob stunts
« Reply #6 on: April 16, 2014, 10:10:28 AM »
After I drew the original plans, Dan Banjock and I used to fly 2 up. We had a blast. A few years ago Joe Gilbert, Marvin Denny and I flew 3 up. Lot's of fun.
As to neat maneuvers:
A slow slow wing over. Start with the wind to you back and climb. You can also do this and reverse at the top and come back down to whatever else you want to do. I have also done the letters of the alphabet. Also, back down in a hover, land on the tail flipping back to the landing gear and the take off again. This is rough on the elevator, but is fun.  I've done that in demos. I have done a whole flight without ever completing a lap. How about vertical eights with the tops at 45 degrees?
If you can think something up, you can do it.
John Bender's "House" sounds interesting. This could also be used in a freestyle stunt event.
Since I published the Slob in FM, it has become an international disease!
AMA 7544
Re: Bi-Slob stunts
« Reply #7 on: April 17, 2014, 09:24:39 AM »
I could not resist......I could not. Have a Brodack ARF Bi-Slob on the way. Will strap on the OS .35. Don't want to worry about flying it so an ARF will set me free.
Just never have seen a CL plane fly like that and I gotta fell that feeling.
Offline John Craig
Re: Bi-Slob stunts
« Reply #8 on: April 20, 2014, 12:36:19 PM »
My Bi-Slob was built from those plans.  It hung in the garage for 15+ years,  I just started flying it regularly as my flying skills have much improved.  It has more hangar rash that crash damage.
Thank You Tom ! #^
Offline kenneth cook
Re: Bi-Slob stunts
« Reply #9 on: April 20, 2014, 04:20:45 PM »
        I really like the slow over the top wingover that the slob does. I bail out as it feels like it will never make it over the top. My son Shawn and Dan Banjock just let them fly over. Really cool to see especially when you pull out inverted on the other side . Ken
Re: Bi-Slob stunts
« Reply #10 on: April 20, 2014, 07:25:41 PM »
One I have wanted to try is a reverse wingover by doing it against the wind and then doing a 180 at the bottom upwind to come back over the circle the other way. No guts yet.
Re: Bi-Slob stunts
« Reply #11 on: April 21, 2014, 09:54:12 AM »
Ask John B. about my first flight with the Bi-Slob.   Was too fast to get a hover so I did do several reverse wing overs into the wind of the day.   Would not try it with the Candy that I had.
Re: Bi-Slob stunts
« Reply #12 on: April 28, 2014, 08:17:47 PM »
Got the Brodak Bi-Slob put together today. Bit head-scratchy at times as it is hard to see the pictures in the instructions but it all makes sense if you keep placing things together before gluing. Re-did the covering on the tail as it was so loose and bubbly. But I reckon I expected that in a ARF. Took me about 7 hours. Had to trim the nose up a bit to fit the OS .35.
Oh, I beg forgiveness and understanding for not using a Fox.35.
 If someone wants to send me one I'll strap it on the nose.... ;D :##
 Thinking 51' to 55' lines to start. Does that seem about right?
Now c'mon weather......excited about this plane after watching videos of flights. Trippy.
« Last Edit: April 28, 2014, 11:00:51 PM by Shug Emery »
Re: Bi-Slob stunts
« Reply #13 on: April 29, 2014, 09:55:01 AM »
Line length sounds about right.   Also a low pitched prop.
Re: Bi-Slob stunts
« Reply #14 on: April 29, 2014, 08:27:13 PM »
Got some 10-5s and going to get some 10-4s. Thanks.
Re: Bi-Slob stunts
« Reply #15 on: April 30, 2014, 08:33:48 AM »
Really you should look up Jim Lee in the members list and PM him as he is our local Bi-Slob guy.   I have seen him do things with it that a plane is not supposed to do.
Re: Bi-Slob stunts
« Reply #16 on: May 05, 2014, 04:42:07 PM »
Does one want the Bi-Slob on the tail heavy side?
Thanks for any info.
Re: Bi-Slob stunts
« Reply #17 on: May 06, 2014, 09:46:13 AM »
Not really.  Really though it should be balanced the way you want to fly.  To tell the truth I've never checked the balance point on mine.  My Brother-in-law made his third control  line flight on my Bi-Slob and loved it.
Offline John Craig
Re: Bi-Slob stunts
« Reply #18 on: May 06, 2014, 10:58:28 AM »
I must also confess that I have never checked or been concerned about the CG on my Bi-Slob.  It just flies.
Re: Bi-Slob stunts
« Reply #19 on: May 07, 2014, 09:52:45 AM »
I appreciate the advice guys.
Now...to practice and get bold!
Offline bob whitney
Re: Bi-Slob stunts
« Reply #20 on: May 07, 2014, 02:05:51 PM »
how about a 2.4 throttle on a Slob
rad racer
Offline KenP51
  • K Pitts
Re: Bi-Slob stunts
« Reply #21 on: May 07, 2014, 03:02:48 PM »
Sounds fun to me.
But as for me and my house, we will serve the Lord
